NXP iMX95: ARM SMMU problem with PCIe
1,303 次查看
pierluigi_p
Senior Contributor I
Dear NXP support,
we are trying to integrate a PCIe-USB bridge eval kit (https://www.microchip.com/en-us/development-tool/ev96n38a) with NXP iMX95 using kernel 6.12.49.
The PCIe bridge successfully completes PCIe enumeration and all endpoints (xHCI controller, i2c controller, etc.) show up when running "lspci".
When plugging in a USB device (flash drive, keyboard, etc.) to a USB port on the PCI11400 eval kit, the following messages are listed
[ 1631.912942] arm-smmu-v3 490d0000.iommu: event 0x10 received:
[ 1631.918618] arm-smmu-v3 490d0000.iommu: 0x0000001000000010
[ 1631.924188] arm-smmu-v3 490d0000.iommu: 0x0000020200000000
[ 1631.929760] arm-smmu-v3 490d0000.iommu: 0x0000000000000000
[ 1631.935326] arm-smmu-v3 490d0000.iommu: 0x0000000000000000
but no USB device is actually enumerated.
Suspecting some kind of problem with ARM SMMU translation we added "iommu.passthrough=1" to the kernel command line: with this change, the USB devices are correctly enumerated.
However, "iommu.passthrough=1" allows accessing to protected memory regions (i.e. encryption keys) and cannot be considered a valid workaround from a security perspective.
Could you propose any alternative solution ?
Best Regards
Pier
标记 (3)
1,258 次查看
Zhiming_Liu
Hi @pierluigi_p
It looks like that the PCIe-USB bridge you are using is accessing SMMU IDs other than the SID and RID allowed by the i.MX95 PCI node.
Below are the SMMU settings for the i.mx95 PCIe. i think you should figure out the actual SID and RID mapping used by the PCI11400.
			iommu-map = <0x000 &smmu 0x10 0x1>,
				    <0x100 &smmu 0x11 0x7>;
			iommu-map-mask = <0x1ff>;
Zhiming
1,259 次查看
Zhiming_Liu
Hi @pierluigi_p
Zhiming
1,097 次查看
pierluigi_p
Hi @Zhiming_Liu,
thanks for the suggestion.
Best Regards
Pier
%3CLINGO-SUB%20id%3D%22lingo-sub-2372049%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%81%A9%E6%99%BA%E6%B5%A6%20iMX95%EF%BC%9APCIe%20%E7%9A%84%20ARM%20SMMU%20%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2372049%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BA%B2%E7%88%B1%E7%9A%84%E6%81%A9%E6%99%BA%E6%B5%A6%E6%94%AF%E6%8C%81%E4%BA%BA%E5%91%98%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%E5%86%85%E6%A0%B8%206.12.49%20%E5%B0%86%20PCIe-USB%20%E6%A1%A5%E6%8E%A5%E8%AF%84%E4%BC%B0%E5%A5%97%E4%BB%B6%20(%3CA%20href%3D%22https%3A%2F%2Fwww.microchip.com%2Fen-us%2Fdevelopment-tool%2Fev96n38a%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.microchip.com%2Fen-us%2Fdevelopment-tool%2Fev96n38a%3C%2FA%3E)%20%E4%B8%8E%E6%81%A9%E6%99%BA%E6%B5%A6%20iMX95%20%E9%9B%86%E6%88%90%E3%80%82%3C%2FP%3E%3CP%3E%E5%BD%93%E8%BF%90%E8%A1%8C%22lspci%22%20%E6%97%B6%EF%BC%8CPCIe%20%E7%BD%91%E6%A1%A5%E6%88%90%E5%8A%9F%E5%AE%8C%E6%88%90%20PCIe%20%E6%9E%9A%E4%B8%BE%E5%B9%B6%E6%98%BE%E7%A4%BA%E6%89%80%E6%9C%89%E7%AB%AF%E7%82%B9%EF%BC%88xHCI%20%E6%8E%A7%E5%88%B6%E5%99%A8%E3%80%81i2c%20%E6%8E%A7%E5%88%B6%E5%99%A8%E7%AD%89%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E5%B0%86%20USB%20%E8%AE%BE%E5%A4%87%EF%BC%88%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E5%99%A8%E3%80%81%E9%94%AE%E7%9B%98%E7%AD%89%EF%BC%89%E6%8F%92%E5%85%A5%20PCI11400%20%E8%AF%84%E4%BC%B0%E5%A5%97%E4%BB%B6%E7%9A%84%20USB%20%E7%AB%AF%E5%8F%A3%E6%97%B6%EF%BC%8C%E4%BC%9A%E5%88%97%E5%87%BA%E4%BB%A5%E4%B8%8B%E6%B6%88%E6%81%AF%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3E%5B1631.912942%5D%20arm-smu-v3%20490d0000.iommu%EF%BC%9A%E6%94%B6%E5%88%B0%E4%BA%8B%E4%BB%B6%200x10%EF%BC%9A%3C%2FP%3E%3CP%3E%5B1631.918618%5D%20arm-smu-v3%20490d0000.iommu%EF%BC%9A0x0000001000000010%3C%2FP%3E%3CP%3E%5B1631.924188%5D%20arm-smu-v3%20490d0000.iommu%EF%BC%9A0x0000020200000000%3C%2FP%3E%3CP%3E%5B1631.929760%5D%20arm-smu-v3%20490d0000.iommu%EF%BC%9A0x0000000000000000%3C%2FP%3E%3CP%3E%5B1631.935326%5D%20arm-smu-v3%20490d0000.iommu%EF%BC%9A0x0000000000000000%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E4%BD%86%E5%AE%9E%E9%99%85%E4%B8%8A%E6%B2%A1%E6%9C%89%20USB%20%E8%AE%BE%E5%A4%87%E8%A2%AB%E6%9E%9A%E4%B8%BE%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E6%80%80%E7%96%91%20ARM%20SMMU%20%E7%9A%84%E7%BF%BB%E8%AF%91%E5%AD%98%E5%9C%A8%E6%9F%90%E7%A7%8D%E9%97%AE%E9%A2%98%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%9C%A8%E5%86%85%E6%A0%B8%E5%91%BD%E4%BB%A4%E8%A1%8C%E4%B8%AD%E6%B7%BB%E5%8A%A0%E4%BA%86%20%22%20iommu.passthrough%3D1%20%22%EF%BC%9A%E9%80%9A%E8%BF%87%E6%AD%A4%E6%AC%A1%E6%9B%B4%E6%94%B9%EF%BC%8C%E5%8F%AF%E4%BB%A5%E6%AD%A3%E7%A1%AE%E6%9E%9A%E4%B8%BE%20USB%20%E8%AE%BE%E5%A4%87%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8C%22iommu.passthrough%3D1%22%E5%85%81%E8%AE%B8%E8%AE%BF%E9%97%AE%E5%8F%97%E4%BF%9D%E6%8A%A4%E7%9A%84%E5%86%85%E5%AD%98%E5%8C%BA%E5%9F%9F%EF%BC%88%E5%8D%B3%E5%8A%A0%E5%AF%86%E5%AF%86%E9%92%A5%EF%BC%89%EF%BC%8C%E4%BB%8E%E7%BD%91%E7%BB%9C%E5%AE%89%E5%85%A8%E8%A7%92%E5%BA%A6%E6%9D%A5%E7%9C%8B%EF%BC%8C%E4%B8%8D%E8%83%BD%E5%B0%86%E5%85%B6%E8%A7%86%E4%B8%BA%E6%9C%89%E6%95%88%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%B3%95%E3%80%82%3C%2FP%3E%3CP%3E%E6%82%A8%E8%83%BD%E6%8F%90%E5%87%BA%E5%85%B6%E4%BB%96%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3E%E7%A0%81%E5%A4%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2372262%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NXP%20iMX95%3A%20ARM%20SMMU%20problem%20with%20PCIe%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2372262%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F60868%22%20target%3D%22_blank%22%3E%40pierluigi_p%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E7%9C%8B%E6%9D%A5%E4%BD%A0%E4%BD%BF%E7%94%A8%E7%9A%84%20PCIe-USB%20%E6%A1%A5%E6%8E%A5%E5%99%A8%E8%AE%BF%E9%97%AE%E7%9A%84%20SMMU%20ID%20%E4%B8%8E%20i.MX95%20PCI%20%E8%8A%82%E7%82%B9%E5%85%81%E8%AE%B8%E7%9A%84%20SID%20%E5%92%8C%20RID%20%E4%B8%8D%E5%90%8C%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%20i.mx95%20PCIe%20%E7%9A%84%20SMMU%20%E8%AE%BE%E7%BD%AE%E3%80%82%E6%88%91%E8%AE%A4%E4%B8%BA%E4%BD%A0%E5%BA%94%E8%AF%A5%E5%BC%84%E6%B8%85%E6%A5%9A%20PCI11400%20%E5%AE%9E%E9%99%85%E4%BD%BF%E7%94%A8%E7%9A%84%20SID%20%E5%92%8C%20RID%20%E6%98%A0%E5%B0%84%E3%80%82%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%09%09%09iommu-map%20%3D%20%26lt%3B0x000%20%26amp%3Bsmmu%200x10%200x1%26gt%3B%2C%0A%09%09%09%09%20%20%20%20%26lt%3B0x100%20%26amp%3Bsmmu%200x11%200x7%26gt%3B%3B%0A%09%09%09iommu-map-mask%20%3D%20%26lt%3B0x1ff%26gt%3B%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%87%B4%E6%95%AC%EF%BC%8C%3CBR%20%2F%3EZhiming%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2376769%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20NXP%20iMX95%3A%20ARM%20SMMU%20problem%20with%20PCIe%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2376769%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F151788%22%20target%3D%22_blank%22%3E%40Zhiming_Liu%3C%2FA%3E%EF%BC%8C%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%E7%9A%84%E5%BB%BA%E8%AE%AE%E3%80%82%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3E%E7%A0%81%E5%A4%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E
