[NXP NFC OM27160A1HN] nfcDemoApp Segmentation Fault
1,235件の閲覧回数
Amine_Ferchichi
We are having a critical issue with the libnfc-nci library.
The nfcDemoApp application runs into a segmentation fault and crashes intermittently after execute nfcDemoApp poll, nfcDemoApp share, nfcDemoApp write and nfcDemoApp push.
I believe the crash happened during nfc_find_conn_cb_by_conn_id() function call.
We are using Linux kernel 4.14.87 and nci library libnfc-nci library.
Attached is the application log as well as debugger log .
タグ(1)
1,174件の閲覧回数
Dhruvit
Hi @Amine_Ferchichi,
I hope you are doing well. I appreciate your cooperation.
Could you please provide me with the following?
  • Which Android BSP version are you using?
  • Which i.MX series processor you are working on?
Thank you.
Dhruvit.
