We are having a critical issue with the libnfc-nci library.
The nfcDemoApp application runs into a segmentation fault and crashes intermittently after execute nfcDemoApp poll, nfcDemoApp share, nfcDemoApp write and nfcDemoApp push.
I believe the crash happened during nfc_find_conn_cb_by_conn_id() function call.
We are using Linux kernel 4.14.87 and nci library libnfc-nci library.
Attached is the application log as well as debugger log .
Hi @Amine_Ferchichi,
I hope you are doing well. I appreciate your cooperation.
Could you please provide me with the following?
Thank you.
Dhruvit.
