NXP 1062 MCU Porting http_client_tls_init() example code issue
2,659 次查看
jackwu
How do I open the all certificate correctly?
I can only enable this program to open one certificate now, other certificate can't open.
(  Ciphersuite is TLS-ECDHE-ECDSA-WITH-AES-128-GCM-SHA256 )
Can you help provide a way to enable more certificate support through program adjustment and help determine the hardware solution and software solution?
Please help provide a method, thank you!
5 回复数
2,590 次查看
kerryzhou
Hi @jackwu ,
   Thanks for your interest in the NXP MIMXRT product, I would like to provide service for you.
   Please tell me which RT1062 demo you are refering, the SDK verson and the demo path in the SDK package, thanks.
  Then I can help you do the detail checking.
Kerry
2,565 次查看
jackwu
Hi , @kerryzhou   thanks for your reply , can you provide me your E-mail address ,via email provide you SDK version .
Thanks!
Jack
2,559 次查看
jackwu
@kerryzhou  NXP 1062 SDK is 2.8.4 version
Thanks .
Jack
2,548 次查看
kerryzhou
Hi @jackwu ,
   Thanks for your information.
   Your SDK is really very old, please use the newest SDK2.14.0:
https://mcuxpresso.nxp.com/en/builder?hw=EVK-MIMXRT1060
  Whether still have the issues or not?
Please also tell me your used sdk project:
\SDK_2_14_0_EVK-MIMXRT1060\boards\evkmimxrt1060\lwip_examples\lwip_httpssrv_mbedTLS\freertos
This one?
Kerry
2,561 次查看
kerryzhou
  If you want the provide support, you can create the private case, then we can discuss it in the email instead of the public community.
  This is the case create flow:
1. Open below SUPPORT site, click blue "Go to Tickets" in the middle.
http://www.nxp.com/support/support:SUPPORTHOME
2.Then you will be requested to Login, if you have no an account, please first Register with your business email.
3.After login, please "Create New Cases" button in the middle, then you can submit your question.
  In your case content, you can write assign to kerry zhou, and also tell me your SDK version, then I will help you.
Kerry
