NVCC_JTAG sequencing for debugging
1,816 次查看
inmaku
Good morning community,
I was just wondering, if the supply for the JTAG Interface (NVCC_JTAG) needs to be supplied before the rest of the CPU supplies in cases, where I want to use the JTAG for start-up Debugging?
标记 (2)
1,735 次查看
Hi Ingo
no, NVCC_JTAG does not need to be supplied before the rest of the CPU supplies,
please follow power-up sequence defined in i.MX6 datasheet.
1,736 次查看
Hi Ingo
