NAND boot efuse GPIO overriding
995 次查看
alexishumblet
Hi all,
I am currently working on a i.MX6UL board with NAND boot. However, looking in the configuration fuse GPIO overriding in the reference manual, I am a bit confused.
On page 258/259 (table 8-10), it is written that fuses 0x470 and 0x6D0 can be overridden by GPIO settings. However, these fuses do not have any references in table 8-3 (GPIO Override Contact Assignments).
I suppose the GPIO column for fuses 0x470 and 0x6D0 should be read "No" instead of "Yes". Am I correct?
Thank you for you help!
0 回复数
