Multi display connection
3,124 次查看
inkyushin
Hi all,
I got in trouble connecting multi display on one i.mx 6 dual lite board in physical way.
Here is what I am trying to do :
We right now have 3 displays.
We are supposed to use one HDMI port, one LVDS and one display parallel for multi connection
Every display panel is attaced with AD board. So, with HDMI port, we are going to use HDMI to DVI cable to connect between NXP board and AD board of one display. But the problem is when we use LVDS. LVDS cable is connected between display and NXP board but how can i connect between NXP board and AD board. Is it supposed to use HDMI to DVI stuff? If so, since there is only one HDMI port which alreay is used in first display, I cannot find a way to connect between this. Maybe there could be other way to connect two display on one NXP board. Please let me know how it works.
According to NXP engineer guy, I need to use LDB port but I cannot figure out how to do it.
For your understanding, i will attach three picture. First one is the document about the display setting. Second one is general outline of what I am trying to do. Third one is where LVDS is used.
Since I never connect multi display on one board, I need your help
Thank you.
3,028 次查看
igorpadykov
Hi Inkyu
do you have board schematic, please look at lvds lcd connection on
Sabre SD schematic spf-27392 p.7
Schematics (1)
"Design files, including hardware schematics, Gerbers, and OrCAD files. (REV C5) "
http://www.nxp.com/products/software-and-tools/hardware-development-tools/sabre-development-system/s...
