Modify Partition Table due to Large U-boot size
1,547 次查看
mdomondon
I have a Sabresd board that I am using for testing. Following the instructions in the Android User's Guide pdf, I built the android images and flashed them to an SD card. I made some changes to the bootloader. I decided to keep the splash screen of the bootloader enabled but I am using own custom bmp file as the image to be displayed...
My problem is that my bootloader file (u-boot-imx6q.imx) exceeds 1 MB because the custom bmp file for my splash screen is large (around 600KB). It looks like the partition table (partition-table.img android image) only allocates a maximum of 1 MB for the bootloader.
Assuming I really need to use my large bmp file (insane, I know), does someone know where and what to modify to change the partition-table.img to accommodate my large bootloader imx file?
Mike
标签 (3)
1,371 次查看
Hi Mike
partitions usage is described in sect.Storage partitions
Android_User's_Guide.pdf included in documetation package on
i.MX Software|NXP
Partitions can be changed using mfg tools scripts (mksdcard-android.sh.tar) found in
/OS Firmware folder.
