Minimum Recommended Ram for Android with i.MX8M Plus
Wobaffet
Senior Contributor I
Hello, what is the min. required ram with i.MX8M Plus for Android? Thank you in advance.
AldoG
it will depend on the Android version you'll be using, and the product you're planning to develop.
Google provide guidelines for this so you'll need to refer to that:
https://source.android.com/docs/compatibility/12/android-12-cdd
Aldo.
AldoG
Aldo.
Wobaffet
Hello, Thank you for the response.
What about Minimum Recommended Ram for Linux with i.MX8M Plus?
AldoG
It is less restrictive, for Linux minimum it could be really low, just please note that according to your use case it would require more or less RAM, one could take the EVK as an ideal value for using the processor.
Aldo.
