Messaging Unit mapping in imx8qm
bghiggins
The IMX8QM manual does a lot to describe the how the Message Unit works IO between Core A and Core B, but it doesn't really describe which MU A are connected to which MU B.  From what I can tell, it seems to be a one to one connection, but I could be wrong.  How can I tell what the MU connections are between the different domains?
Tags (2)
Harvey021
Such documentation(DSC) that I can't access too. You need to contact Local NXP FAE or marketing team to get it.
Harvey
Harvey
bghiggins
It seems the MUs connections are controlled by the DSC (Distributed Slave System Controller).  Is there documentation for that or is that also something I need to get from ARM?
Harvey021
Harvey
Harvey
bghiggins
Is there a good point of contact for the marketing and/or FAE teams?
Harvey021
A better way to reach out your local DFAE, if you know someone who is the one supports for you.
Harvey
Harvey021
Hi @bghiggins
MU is a group of AB, but we have many MUs, such as MU1, MU2, MU3, so for MU1, MU1_A is the one that communicates with MU1_B.
Since the Arch and IP belong to ARM, I would recommend you to refer to ARM sources for more details.
Harvey
