Message unit in iMX7
suryapradhan
I am using iMX7D based board & my objective is to communicate between its two processors (Cortex-A7 &  Cortex-M4).
From technical data sheet of iMX7D i got to know that Message Unit(MU) normally does this work.
Is there any default driver for Message Unit [MU] or reference document for communication between two cores.
Thanks & regards
Surya
Labels (2)
Hi Surya
please look at Chapter 51 Remote Processor Messaging (RPMsg)
attached Linux Manual.
suryapradhan
Hello igor,
Thanks for the reply.
Can you please tell me where can i get  rpmsg_str_echo_sdk_7dsdb.bin ,rpmsg_str_echo_sdk_7dsdb.bin  image files.
Thanks & regards
Surya
Hi Surya
seems it is necessary to generate them by building image, use guidelines in
