Memmory configuration for IMX93 1GB
1,329件の閲覧回数
logan3c3
Hi i need to modify dts to adapt to 1GB ddr i have modified and its working but when i tried to run an ai example it crashes and wont run. can anyone confirm if my dts is correct.
if possible can you give examples of 1GB 512MB and 256MB
reserved-memory {
		#address-cells = <2>;
		#size-cells = <2>;
		ranges;
		linux,cma {
			compatible = "shared-dma-pool";
			reusable;
			alloc-ranges = <0 0x80000000 0 0x20000000>;
			size = <0 0x8000000>;
			linux,cma-default;
		ethosu_mem: ethosu_region@A0000000 {
			reusable;
			reg = <0x0 0xA0000000 0x0 0x800000>;
		vdev0vring0: vdev0vring0@92000000 {
			reg = <0 0x92000000 0 0x8000>;
			no-map;
		vdev0vring1: vdev0vring1@92008000 {
			reg = <0 0x92008000 0 0x8000>;
			no-map;
		vdev1vring0: vdev1vring0@92010000 {
			reg = <0 0x92010000 0 0x8000>;
			no-map;
		vdev1vring1: vdev1vring1@92018000 {
			reg = <0 0x92018000 0 0x8000>;
			no-map;
		rsc_table: rsc-table@2021e000 {
			reg = <0 0x2021e000 0 0x1000>;
			no-map;
		vdevbuffer: vdevbuffer@92020000 {
			reg = <0 0x92020000 0 0x100000>;
			no-map;
		ele_reserved: ele-reserved@92120000 {
			reg = <0 0x92120000  0 0x100000>;
			no-map;
 @imx93
ラベル(2)
タグ(3)
3 返答(返信)
1,299件の閲覧回数
JorgeCas
What you need to configure in your board to use 1GB of RAM is the next:
• Generate the 1GByte timing.c file in Config Tool.
• ccange the DRAM size to 1GB. uboot-imx/include/configs/imx93_evk.h
Here an example:
Best regards.
1,288件の閲覧回数
logan3c3
@JorgeCas thanks for the answer. i have generated the ddr files and modified everything accordingly can you just let me know if the dts is correct if not provide an example.
1,282件の閲覧回数
JorgeCas
I do not see issues in your configuration.
These settings are application dependent. So you need to estimate how many buffers is required for peripherals.
If you application is crashing could be because CMA pool too small.
Also please confirm if reserved regions don’t exceed physical RAM.
Best regards.
%3CLINGO-SUB%20id%3D%22lingo-sub-2145663%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIMX93%201GB%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E6%A7%8B%E6%88%90%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2145663%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%821GB%20DDR%20%E3%81%AB%E9%81%A9%E5%90%88%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%20DTS%20%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E5%A4%89%E6%9B%B4%E3%81%AF%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81AI%20%E3%81%AE%E4%BE%8B%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%82%AF%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%A6%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E7%A7%81%E3%81%AEDTS%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E8%AA%B0%E3%81%8BCAN%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%82%E3%82%8C%E3%81%B0%E3%80%811GB%E3%80%81512MB%E3%80%81256MB%E3%81%AE%E4%BE%8B%E3%82%92%E6%8C%99%E3%81%92%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3Ereserved-memory%20%7B%0A%09%09%23address-cells%20%3D%20%26lt%3B2%26gt%3B%3B%0A%09%09%23size-cells%20%3D%20%26lt%3B2%26gt%3B%3B%0A%09%09ranges%3B%0A%0A%09%09linux%2Ccma%20%7B%0A%09%09%09compatible%20%3D%20%22shared-dma-pool%22%3B%0A%09%09%09reusable%3B%0A%09%09%09alloc-ranges%20%3D%20%26lt%3B0%200x80000000%200%200x20000000%26gt%3B%3B%0A%09%09%09size%20%3D%20%26lt%3B0%200x8000000%26gt%3B%3B%0A%09%09%09linux%2Ccma-default%3B%0A%09%09%7D%3B%0A%0A%09%09ethosu_mem%3A%20ethosu_region%40A0000000%20%7B%0A%09%09%09compatible%20%3D%20%22shared-dma-pool%22%3B%0A%09%09%09reusable%3B%0A%09%09%09reg%20%3D%20%26lt%3B0x0%200xA0000000%200x0%200x800000%26gt%3B%3B%0A%09%09%7D%3B%0A%20%20%0A%09%09vdev0vring0%3A%20vdev0vring0%4092000000%20%7B%0A%09%09%09reg%20%3D%20%26lt%3B0%200x92000000%200%200x8000%26gt%3B%3B%0A%09%09%09no-map%3B%0A%09%09%7D%3B%0A%0A%09%09vdev0vring1%3A%20vdev0vring1%4092008000%20%7B%0A%09%09%09reg%20%3D%20%26lt%3B0%200x92008000%200%200x8000%26gt%3B%3B%0A%09%09%09no-map%3B%0A%09%09%7D%3B%0A%0A%09%09vdev1vring0%3A%20vdev1vring0%4092010000%20%7B%0A%09%09%09reg%20%3D%20%26lt%3B0%200x92010000%200%200x8000%26gt%3B%3B%0A%09%09%09no-map%3B%0A%09%09%7D%3B%0A%0A%09%09vdev1vring1%3A%20vdev1vring1%4092018000%20%7B%0A%09%09%09reg%20%3D%20%26lt%3B0%200x92018000%200%200x8000%26gt%3B%3B%0A%09%09%09no-map%3B%0A%09%09%7D%3B%0A%0A%09%09rsc_table%3A%20rsc-table%402021e000%20%7B%0A%09%09%09reg%20%3D%20%26lt%3B0%200x2021e000%200%200x1000%26gt%3B%3B%0A%09%09%09no-map%3B%0A%09%09%7D%3B%0A%0A%09%09vdevbuffer%3A%20vdevbuffer%4092020000%20%7B%0A%09%09%09compatible%20%3D%20%22shared-dma-pool%22%3B%0A%09%09%09reg%20%3D%20%26lt%3B0%200x92020000%200%200x100000%26gt%3B%3B%0A%09%09%09no-map%3B%0A%09%09%7D%3B%0A%0A%09%09ele_reserved%3A%20ele-reserved%4092120000%20%7B%0A%09%09%09compatible%20%3D%20%22shared-dma-pool%22%3B%0A%09%09%09reg%20%3D%20%26lt%3B0%200x92120000%20%200%200x100000%26gt%3B%3B%0A%09%09%09no-map%3B%0A%09%09%7D%3B%0A%09%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%40imx93%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2145663%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EYocto%20Project%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2147010%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Memmory%20configuration%20for%20IMX93%201GB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2147010%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%E8%A8%AD%E5%AE%9A%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A6%8B%E5%BD%93%E3%81%9F%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AF%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E4%BE%9D%E5%AD%98%E3%81%97%E3%81%BE%E3%81%99%E3%80%82SO%E3%80%81%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E6%95%B0%E3%82%92%E8%A6%8B%E7%A9%8D%E3%82%82%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E3%82%AF%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81CMA%20%E3%83%97%E3%83%BC%E3%83%AB%E3%81%8C%E5%B0%8F%E3%81%95%E3%81%99%E3%81%8E%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E5%8E%9F%E5%9B%A0%E3%81%A7%E3%81%82%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E4%BA%88%E7%B4%84%E9%A0%98%E5%9F%9F%E3%81%8C%E7%89%A9%E7%90%86%20RAM%20%E3%82%92%E8%B6%85%E3%81%88%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%82%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2146763%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Memmory%20configuration%20for%20IMX93%201GB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2146763%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203308%22%20target%3D%22_blank%22%3E%40JorgeCas%3C%2FA%3E%E5%9B%9E%E7%AD%94%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82DDR%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E3%81%99%E3%81%B9%E3%81%A6%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82CAN%20%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E4%BE%8B%E3%82%92%E6%8C%99%E3%81%92%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2146317%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Memmory%20configuration%20for%20IMX93%201GB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2146317%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E1GB%20%E3%81%AE%20RAM%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E2%80%A2%201GByte%E3%81%AEtiming.c%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8BConfig%20Tool%20%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%82%3CBR%20%2F%3E%20%E2%80%A2%20DRAM%20%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%92%201GB%20%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82uboot-imx%2Finclude%2Fconfigs%2Fimx93_evk.h%3C%2FP%3E%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AB%E4%BE%8B%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%202025-08-04%20110203.png%22%20style%3D%22width%3A%20988px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%202025-08-04%20110203.png%22%20style%3D%22width%3A%20988px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F350831iC56DDDC34AD993F7%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Screenshot%202025-08-04%20110203.png%22%20alt%3D%22Screenshot%202025-08-04%20110203.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
