May I not populate PF0100 F0 SWBST components?
已解决
跳至解决方案
2,143 次查看
MehmetAliIpin
Contributor V
Dear Sir/Madam,
We have a project with I.MX6 dual/quad core processor which we use PF0100 F0 as PMIC. For USB I have another 5 volts supply already and therefore I don't want to populate SWBST components in PCB. Does it cause stability problems to PF0100 F0?
Thanks and best regards.
Mehmet Ali
标记 (2)
1 解答
2,013 次查看
durmus
Hi Mehmet Ali,
You should check out the following document:
http://cache.freescale.com/files/analog/doc/app_note/AN4717.pdf
For every pin, there is a column for "Recommended connection when not used".
For your specific question, it says in the document:
44 - SWBSTFB --> Leave floating
45 - SWBSTIN --> Connect to VIN
46 - SWBSTLX --> Leave floating
Durmuş
在原帖中查看解决方案
2 回复数
2,014 次查看
durmus
Hi Mehmet Ali,
Durmuş
2,013 次查看
MehmetAliIpin
Contributor V
Thank you,
I found and read AN4717 after I asked the question.
Best regards.
Mehmet Ali
