Maximum Data rate and clock for QSPI interface of i.MX8M mini
241 次查看
mk031
what is the maximum data rate and clock for the QSPI interface supported by i.MX8M Mini Processor?
230 次查看
Zhiming_Liu
Please refer the datasheet.
https://www.nxp.com/docs/en/data-sheet/IMX8MMCEC.pdf
Zhiming
151 次查看
mk031
Thanks for your valuable reply, @Zhiming_Liu .
Can you please confirm the maximum clock/data rate of QSPI interface supported by i.MX8M Plus processor
140 次查看
Zhiming_Liu
SDR (single data rate) SCK = 166 MHz (max). That’s 166M transfers/sec.
DDR mode also lists 166 MHz as the clock but transfers on both edges, so DDR effectively gives 2 transfers/clock (≈332 MT/s)
Zhiming
