Make pixel wise operation on framebuffer
JustinChou
Platform: IMX6  Android 4.4.2
I would make pixel wise operation on framebuffer (/dev/graphic/fb0, how to modify the driver? I want to resize, pan and rotate the content of framebuffer.
I have a Unity application program which will generate 1920x1080px60 LVDS output but it need to be warped, and I think software de-warping is an available solution.
Should I modify framebuffer driver directly?  If I could look into some code examples that would be great.
joanxie
pls refer to the enclosed sample code, hope helpful for you
This sample code for CSC settings for /dev/fb1.
It can calculating the CSC matrix and updates in real time from given parameters(Brightness,Contrast,Saturation,Hue, and gamma).
