MX8ULP_DDR_Tool
MX8ULP_DDR_Tool
Joerg_Ks
Hi Guys,
we use your MX8ULP_DDR_Tool to check our LPDDR4x design. I have a question regarding the tool. Is the code that runs the tests located in the internal ram of 8ulp? When I run the stress test on several boards, I see that sometimes the tools hangs without an error or message from the cpu in the terminal.
Thank you in advance.
BR Joerg
JorgeCas
The tool is running on the PC side which downloads a test image to the i.MX series processor’s internal RAM through a USB connection.
Best regards.
Joerg_Ks
Hi Jorge,
to narrow it in another way, can NXP provide a list of errormessages, that the image can send to the customer? Maybe you can send me a link to the source o the image git?
BR Joerg
Tags (2)
JorgeCas
We do not have a list of error messages from the tool.
Usually the error log shows the cause of the issue.
Best regards.
Joerg_Ks
Hi Jorge,
can we have access to the sources of that Ramtest image? Thank you in advance.
JorgeCas
Unfortunately there are no source code available of DDR tool.
Best regards.
Joerg_Ks
Hi Jorge,
this was also my understanding. So the external RAM is only for testing and it should not matter if there is something wrong, the image should run. I would expect some error messages when there is a test that fails. But what I see is, that the test image stops running. Is there a way to check if the image is still running over the serial port?
BR Joerg
%3CLINGO-SUB%20id%3D%22lingo-sub-2175032%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMX8ULP_DDR_Tool%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2175032%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Guys%2C%3C%2FP%3E%3CP%3Ewe%20use%20your%26nbsp%3BMX8ULP_DDR_Tool%20to%20check%20our%20LPDDR4x%20design.%20I%20have%20a%20question%20regarding%20the%20tool.%20Is%20the%20code%20that%20runs%20the%20tests%20located%20in%20the%20internal%20ram%20of%208ulp%3F%20When%20I%20run%20the%20stress%20test%20on%20several%20boards%2C%20I%20see%20that%20sometimes%20the%20tools%20hangs%20without%20an%20error%20or%20message%20from%20the%20cpu%20in%20the%20terminal.%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThank%20you%20in%20advance.%3C%2FP%3E%3CP%3EBR%20Joerg%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2179418%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MX8ULP_DDR_Tool%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2179418%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3EUnfortunately%20there%20are%20no%20source%20code%20available%20of%20DDR%20tool.%26nbsp%3B%3C%2FP%3E%0A%3CP%3EBest%20regards.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2179265%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MX8ULP_DDR_Tool%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2179265%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Jorge%2C%3C%2FP%3E%3CP%3Ecan%20we%20have%20access%20to%20the%20sources%20of%20that%20Ramtest%20image%3F%20Thank%20you%20in%20advance.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2176816%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MX8ULP_DDR_Tool%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2176816%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3EWe%20do%20not%20have%20a%26nbsp%3Blist%20of%20error%20messages%20from%20the%20tool.%3C%2FP%3E%0A%3CP%3EUsually%20the%20error%20log%20shows%20the%20cause%20of%20the%20issue.%3C%2FP%3E%0A%3CP%3EBest%20regards.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2176483%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MX8ULP_DDR_Tool%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2176483%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Jorge%2C%3C%2FP%3E%3CP%3Eto%20narrow%20it%20in%20another%20way%2C%20can%20NXP%20provide%20a%20list%20of%20errormessages%2C%20that%20the%20image%20can%20send%20to%20the%20customer%3F%20Maybe%20you%20can%20send%20me%20a%20link%20to%20the%20source%20o%20the%20image%20git%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThank%20you%20in%20advance.%3C%2FP%3E%3CP%3EBR%20Joerg%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2175200%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MX8ULP_DDR_Tool%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2175200%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Jorge%2C%3C%2FP%3E%3CP%3Ethis%20was%20also%20my%20understanding.%20So%20the%20external%20RAM%20is%20only%20for%20testing%20and%20it%20should%20not%20matter%20if%20there%20is%20something%20wrong%2C%20the%20image%20should%20run.%20I%20would%20expect%20some%20error%20messages%20when%20there%20is%20a%20test%20that%20fails.%20But%20what%20I%20see%20is%2C%20that%20the%20test%20image%20stops%20running.%20Is%20there%20a%20way%20to%20check%20if%20the%20image%20is%20still%20running%20over%20the%20serial%20port%3F%3C%2FP%3E%3CP%3EBR%20Joerg%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2175184%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MX8ULP_DDR_Tool%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2175184%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3EThe%20tool%20is%20running%20on%20the%20PC%20side%20which%20downloads%20a%20test%20image%20to%20the%20i.MX%20series%20processor%E2%80%99s%20internal%20RAM%20through%20a%20USB%20connection.%3C%2FP%3E%0A%3CP%3EBest%20regards.%3C%2FP%3E%3C%2FLINGO-BODY%3E
