MX7 JTAG Interface pullup/down
1,939 次查看
demoniacmilk
Hello!
The MX7 datasheet states that no external pullups/downs are required on JTAG but if desired pullups of ~10k may be used (except on TDO and MODE).
The reference design ha pullups on TDS and TDI. Not on TCK. Whats the benefit of adding the pullups? And why was none added on the TCK line?
Thank you.
标签 (2)
1,813 次查看
igorpadykov
Hi Lars
weak resistors make signal susceptible to noise, so
based on specific board design additional pull resistors may be added
for improving board noise resistance.
1,814 次查看
igorpadykov
Hi Lars
