MX53 streaming problem -blog archive
1,998 次查看
prannoy
I am using MX53qsb with ltib.
Now i am facing a problem streaming using gst-launch.
I run this commands,
Mx53:
  gst-launch-0.10 -v v4l2src device=/dev/video0 ! video/x-raw-yuv,width=320,height=240 !  mfw_ipucsc ! mfw_vpuencoder width=320 height=240 codec-type=std_mjpg ! rtpjpegpay ! udpsink host=192.168.1.110 auto-multicast=false port=5000 sync=false
Host(ubuntu 11.10):
   gst-launch -vvv  udpsrc port=5000 ! 'application/x-rtp, media=video, payload=96, clock-rate=90000, encoding-name=JPEG' ! rtpjpegdepay ! ffdec_mjpeg ! xvimagesink
I am getting incorrect image30-stream.jpg like this.
Any one can tell me suggestion......?
标记 (1)
4 回复数
1,913 次查看
Bhavana
 I have successful in live streaming over the internal network...Can anyone help me in streaming the video from client machine to a browser....i.e., we should be capable of viewing the live streaming through the browser...
1,913 次查看
BrilliantovKiri
Senior Contributor I
Bhavana, for host you can use repository, e.g. for Debian aptitude install libjpeg, for board you can build libjpeg via ltib.
1,913 次查看
Bhavana
Missing libgstjpeg.so file...Can anyone please help us out in resloving the issue..
am trying to stream using smokeenc.
1,913 次查看
BrilliantovKiri
Hello, with software encoding you will get correct image, I describe this here
