MIPI-HDMI Converter IC
已解决
跳至解决方案
6,722 次查看
haryanl
I want to use HDMI for my IMX8M Mini custom board.
I have consulted NXP's IMX-MIPI-HDMI board, but I cannot buy MIPI / HDMI converter IC ADV7535
so can i replace it with another IC?
Thank you
标记 (2)
1 解答
6,606 次查看
diegoadrian
We do not recommend that. Since all of our designs and drivers are working with that device. You will need to implement a whole new configuration with the new device. I suggest you contact "Analog Devices" to see how you could get the IC.
Diego.
在原帖中查看解决方案
3 回复数
4,881 次查看
saravanaprabhusk
Where I can procure the IMX-MIPI-HDMI board? Do share the link or portal.
Prabhu
6,607 次查看
diegoadrian
Diego.
6,606 次查看
haryanl
Thank you for your reply.
I understand that
