MIMXRT1060-EVK backlight control
mspenard603
Is there demo code to control the LCD backlight on the IMXRT1060-EVK?
ToNato
Hi NXP,
I'm using RT1060 for our product. I am also having issues with GPIO_B1_15 to generate PWM for backlight. I have some questions.
1- What XBARA is used with GPIO_B1_15_FLEXPWM4_PWMA03? 1, 2, 3?
2- Can you write for us a simple code to configure for properly? I'm trying one day but I cannot configure successfully although, the SDK example is working well on board.
jingpan
There is no direct backlight demo. In all lcd demo, GPIO_B1_15 works as gpio. In backlight circuit, UM1661 support PWM dimming control. Please refer to the PWM demo in SDK.
Jing
mspenard603
Hi Jing,
 Thanks, started to look at the PWM demo. The backlight on GPIO_B1_15 is PWM4_PWMA03. Trying to figure out how to plumb that. I have the following but I'm not seeing anything on my scope.
* Copyright (c) 2015, Freescale Semiconductor, Inc.
* Copyright 2016-2017 NXP
* All rights reserved.
* SPDX-License-Identifier: BSD-3-Clause
#include "fsl_debug_console.h"
#include "board.h"
#include "fsl_pwm.h"
#include "pin_mux.h"
#include "fsl_xbara.h"
* Definitions
/* The PWM base address */
#define BOARD_PWM_BASEADDR PWM4 //PWM1 mls
#define PWM_SRC_CLK_FREQ CLOCK_GetFreq(kCLOCK_IpgClk)
* Prototypes
* Variables
* Code
static void PWM_DRV_Init3PhPwm(void)
uint16_t deadTimeVal;
pwm_signal_param_t pwmSignal[2];
uint32_t pwmSourceClockInHz;
uint32_t pwmFrequencyInHz = 1000;
pwmSourceClockInHz = PWM_SRC_CLK_FREQ;
/* Set deadtime count, we set this to about 650ns */
deadTimeVal = ((uint64_t)pwmSourceClockInHz * 650) / 1000000000;
pwmSignal[0].pwmChannel = kPWM_PwmA;
pwmSignal[0].level = kPWM_HighTrue;
pwmSignal[0].dutyCyclePercent = 50; /* 1 percent dutycycle */
pwmSignal[0].deadtimeValue = deadTimeVal;
pwmSignal[1].pwmChannel = kPWM_PwmB;
pwmSignal[1].level = kPWM_HighTrue;
/* Dutycycle field of PWM B does not matter as we are running in PWM A complementary mode */
pwmSignal[1].dutyCyclePercent = 50;
pwmSignal[1].deadtimeValue = deadTimeVal;
/*********** PWMA_SM0 - phase A, configuration, setup 2 channel as an example ************/
PWM_SetupPwm(BOARD_PWM_BASEADDR, kPWM_Module_0, pwmSignal, 2, kPWM_SignedCenterAligned, pwmFrequencyInHz,
pwmSourceClockInHz);
/*********** PWMA_SM1 - phase B configuration, setup PWM A channel only ************/
PWM_SetupPwm(BOARD_PWM_BASEADDR, kPWM_Module_1, pwmSignal, 1, kPWM_SignedCenterAligned, pwmFrequencyInHz,
/*********** PWMA_SM2 - phase C configuration, setup PWM A channel only ************/
PWM_SetupPwm(BOARD_PWM_BASEADDR, kPWM_Module_2, pwmSignal, 1, kPWM_SignedCenterAligned, pwmFrequencyInHz,
/*********** PWMA_SM3 - phase C configuration, setup PWM A channel only ************/
PWM_SetupPwm(BOARD_PWM_BASEADDR, kPWM_Module_3, pwmSignal, 1, kPWM_SignedCenterAligned, pwmFrequencyInHz,
* @brief Main function
int main(void)
/* Structure of initialize PWM */
pwm_config_t pwmConfig;
static uint16_t delay;
uint32_t pwmVal = 4;
uint16_t i;
/* Board pin, clock, debug console init */
BOARD_ConfigMPU();
BOARD_InitPins();
BOARD_BootClockRUN();
BOARD_InitDebugConsole();
CLOCK_SetDiv(kCLOCK_AhbDiv, 0x2); /* Set AHB PODF to 2, divide by 3 */
CLOCK_SetDiv(kCLOCK_IpgDiv, 0x3); /* Set IPG PODF to 3, divede by 4 */
/* Set the PWM Fault inputs to a low value */
XBARA_Init(XBARA1);
XBARA_SetSignalsConnection(XBARA1, kXBARA1_InputLogicHigh, kXBARA1_OutputFlexpwm1Fault0);
XBARA_SetSignalsConnection(XBARA1, kXBARA1_InputLogicHigh, kXBARA1_OutputFlexpwm1Fault1);
XBARA_SetSignalsConnection(XBARA1, kXBARA1_InputLogicHigh, kXBARA1_OutputFlexpwm1234Fault2);
XBARA_SetSignalsConnection(XBARA1, kXBARA1_InputLogicHigh, kXBARA1_OutputFlexpwm1234Fault3);
PRINTF("FlexPWM driver example\n");
* pwmConfig.enableDebugMode = false;
* pwmConfig.enableWait = false;
* pwmConfig.reloadSelect = kPWM_LocalReload;
* pwmConfig.faultFilterCount = 0;
* pwmConfig.faultFilterPeriod = 0;
* pwmConfig.clockSource = kPWM_BusClock;
* pwmConfig.prescale = kPWM_Prescale_Divide_1;
* pwmConfig.initializationControl = kPWM_Initialize_LocalSync;
* pwmConfig.forceTrigger = kPWM_Force_Local;
* pwmConfig.reloadFrequency = kPWM_LoadEveryOportunity;
* pwmConfig.reloadLogic = kPWM_ReloadImmediate;
* pwmConfig.pairOperation = kPWM_Independent;
PWM_GetDefaultConfig(&pwmConfig);
/* Use full cycle reload */
pwmConfig.reloadLogic = kPWM_ReloadPwmFullCycle;
/* PWM A & PWM B form a complementary PWM pair */
pwmConfig.pairOperation = kPWM_ComplementaryPwmA;
pwmConfig.enableDebugMode = true;
/* Initialize submodule 0 */
if (PWM_Init(BOARD_PWM_BASEADDR, kPWM_Module_0, &pwmConfig) == kStatus_Fail)
PRINTF("PWM initialization failed\n");
return 1;
/* Initialize submodule 1 */
pwmConfig.clockSource = kPWM_Submodule0Clock;
pwmConfig.initializationControl = kPWM_Initialize_MasterSync;
if (PWM_Init(BOARD_PWM_BASEADDR, kPWM_Module_1, &pwmConfig) == kStatus_Fail)
return 1;
/* Initialize submodule 2 the same way as submodule 1 */
if (PWM_Init(BOARD_PWM_BASEADDR, kPWM_Module_2, &pwmConfig) == kStatus_Fail)
return 1;
/* Initialize submodule 3 the same way as submodule 1 */
if (PWM_Init(BOARD_PWM_BASEADDR, kPWM_Module_3, &pwmConfig) == kStatus_Fail)
return 1;
/* Call the init function with demo configuration */
PWM_DRV_Init3PhPwm();
/* Set the load okay bit for all submodules to load registers from their buffer */
PWM_SetPwmLdok(BOARD_PWM_BASEADDR, kPWM_Control_Module_0 | kPWM_Control_Module_1 | kPWM_Control_Module_2 | kPWM_Control_Module_3, true);
/* Start the PWM generation from Submodules 0, 1 and 2 */
PWM_StartTimer(BOARD_PWM_BASEADDR, kPWM_Control_Module_0 | kPWM_Control_Module_1 | kPWM_Control_Module_2 | kPWM_Control_Module_3);
delay = 0x0fffU;
while (1U)
for (i = 0U; i < delay; i++)
__ASM volatile("nop");
pwmVal = pwmVal + 4;
/* Reset the duty cycle percentage */
if (pwmVal > 100)
pwmVal = 4;
/* Update duty cycles for all 3 PWM signals */
PWM_UpdatePwmDutycycle(BOARD_PWM_BASEADDR, kPWM_Module_0, kPWM_PwmA, kPWM_SignedCenterAligned, pwmVal);
PWM_UpdatePwmDutycycle(BOARD_PWM_BASEADDR, kPWM_Module_1, kPWM_PwmA, kPWM_SignedCenterAligned, (pwmVal >> 1));
PWM_UpdatePwmDutycycle(BOARD_PWM_BASEADDR, kPWM_Module_2, kPWM_PwmA, kPWM_SignedCenterAligned, (pwmVal >> 2));
PWM_UpdatePwmDutycycle(BOARD_PWM_BASEADDR, kPWM_Module_3, kPWM_PwmA, kPWM_SignedCenterAligned, (pwmVal >> 3));
jingpan
have you change the pin configuration in BOARD_InitPins()?
Jing
%3CLINGO-SUB%20id%3D%22lingo-sub-998321%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMIMXRT1060-EVK%20backlight%20control%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-998321%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIs%20there%20demo%20code%20to%20control%20the%20LCD%20backlight%20on%20the%20IMXRT1060-EVK%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2166177%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MIMXRT1060-EVK%20backlight%20control%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2166177%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20NXP%2C%3C%2FP%3E%3CP%3EI'm%20using%20RT1060%20for%20our%20product.%20I%20am%20also%20having%20issues%20with%26nbsp%3BGPIO_B1_15%20to%20generate%20PWM%20for%20backlight.%20I%20have%20some%20questions.%3C%2FP%3E%3CP%3E1-%20What%20XBARA%20is%20used%20with%20GPIO_B1_15_FLEXPWM4_PWMA03%3F%201%2C%202%2C%203%3F%3C%2FP%3E%3CP%3E2-%20Can%20you%20write%20for%20us%20a%20simple%20code%20to%20configure%20for%20properly%3F%20I'm%20trying%20one%20day%20but%20I%20cannot%20configure%20successfully%20although%2C%20the%20SDK%20example%20is%20working%20well%20on%20board.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-998324%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MIMXRT1060-EVK%20backlight%20control%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-998324%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3Ehave%20you%20change%20the%20pin%20configuration%20in%20BOARD_InitPins()%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ERegards%2C%3C%2FP%3E%3CP%3EJing%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-998323%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MIMXRT1060-EVK%20backlight%20control%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-998323%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Jing%2C%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%26nbsp%3BThanks%2C%20started%20to%20look%20at%20the%20PWM%20demo.%20The%20backlight%20on%20GPIO_B1_15%20is%20PWM4_PWMA03.%20Trying%20to%20figure%20out%20how%20to%20plumb%20that.%20I%20have%20the%20following%20but%20I'm%20not%20seeing%20anything%20on%20my%20scope.%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F*%3CBR%20%2F%3E%20*%20Copyright%20(c)%202015%2C%20Freescale%20Semiconductor%2C%20Inc.%3CBR%20%2F%3E%20*%20Copyright%202016-2017%20NXP%3CBR%20%2F%3E%20*%20All%20rights%20reserved.%3CBR%20%2F%3E%20*%20%3CBR%20%2F%3E%20*%20SPDX-License-Identifier%3A%20BSD-3-Clause%3CBR%20%2F%3E%20*%2F%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%23include%20%22fsl_debug_console.h%22%3CBR%20%2F%3E%23include%20%22board.h%22%3CBR%20%2F%3E%23include%20%22fsl_pwm.h%22%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%23include%20%22pin_mux.h%22%3CBR%20%2F%3E%23include%20%22fsl_xbara.h%22%3CBR%20%2F%3E%2F*******************************************************************************%3CBR%20%2F%3E%20*%20Definitions%3CBR%20%2F%3E%20******************************************************************************%2F%3CBR%20%2F%3E%2F*%20The%20PWM%20base%20address%20*%2F%3CBR%20%2F%3E%23define%20BOARD_PWM_BASEADDR%20PWM4%20%2F%2FPWM1%20mls%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%23define%20PWM_SRC_CLK_FREQ%20CLOCK_GetFreq(kCLOCK_IpgClk)%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F*******************************************************************************%3CBR%20%2F%3E%20*%20Prototypes%3CBR%20%2F%3E%20******************************************************************************%2F%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F*******************************************************************************%3CBR%20%2F%3E%20*%20Variables%3CBR%20%2F%3E%20******************************************************************************%2F%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F*******************************************************************************%3CBR%20%2F%3E%20*%20Code%3CBR%20%2F%3E%20******************************************************************************%2F%3CBR%20%2F%3Estatic%20void%20PWM_DRV_Init3PhPwm(void)%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%20uint16_t%20deadTimeVal%3B%3CBR%20%2F%3E%20pwm_signal_param_t%20pwmSignal%5B2%5D%3B%3CBR%20%2F%3E%20uint32_t%20pwmSourceClockInHz%3B%3CBR%20%2F%3E%20uint32_t%20pwmFrequencyInHz%20%3D%201000%3B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3EpwmSourceClockInHz%20%3D%20PWM_SRC_CLK_FREQ%3B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F*%20Set%20deadtime%20count%2C%20we%20set%20this%20to%20about%20650ns%20*%2F%3CBR%20%2F%3E%20deadTimeVal%20%3D%20((uint64_t)pwmSourceClockInHz%20*%20650)%20%2F%201000000000%3B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3EpwmSignal%5B0%5D.pwmChannel%20%3D%20kPWM_PwmA%3B%3CBR%20%2F%3E%20pwmSignal%5B0%5D.level%20%3D%20kPWM_HighTrue%3B%3CBR%20%2F%3E%20pwmSignal%5B0%5D.dutyCyclePercent%20%3D%2050%3B%20%2F*%201%20percent%20dutycycle%20*%2F%3CBR%20%2F%3E%20pwmSignal%5B0%5D.deadtimeValue%20%3D%20deadTimeVal%3B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3EpwmSignal%5B1%5D.pwmChannel%20%3D%20kPWM_PwmB%3B%3CBR%20%2F%3E%20pwmSignal%5B1%5D.level%20%3D%20kPWM_HighTrue%3B%3CBR%20%2F%3E%20%2F*%20Dutycycle%20field%20of%20PWM%20B%20does%20not%20matter%20as%20we%20are%20running%20in%20PWM%20A%20complementary%20mode%20*%2F%3CBR%20%2F%3E%20pwmSignal%5B1%5D.dutyCyclePercent%20%3D%2050%3B%3CBR%20%2F%3E%20pwmSignal%5B1%5D.deadtimeValue%20%3D%20deadTimeVal%3B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F***********%20PWMA_SM0%20-%20phase%20A%2C%20configuration%2C%20setup%202%20channel%20as%20an%20example%20************%2F%3CBR%20%2F%3E%20PWM_SetupPwm(BOARD_PWM_BASEADDR%2C%20kPWM_Module_0%2C%20pwmSignal%2C%202%2C%20kPWM_SignedCenterAligned%2C%20pwmFrequencyInHz%2C%3CBR%20%2F%3E%20pwmSourceClockInHz)%3B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F***********%20PWMA_SM1%20-%20phase%20B%20configuration%2C%20setup%20PWM%20A%20channel%20only%20************%2F%3CBR%20%2F%3E%20PWM_SetupPwm(BOARD_PWM_BASEADDR%2C%20kPWM_Module_1%2C%20pwmSignal%2C%201%2C%20kPWM_SignedCenterAligned%2C%20pwmFrequencyInHz%2C%3CBR%20%2F%3E%20pwmSourceClockInHz)%3B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F***********%20PWMA_SM2%20-%20phase%20C%20configuration%2C%20setup%20PWM%20A%20channel%20only%20************%2F%3CBR%20%2F%3E%20PWM_SetupPwm(BOARD_PWM_BASEADDR%2C%20kPWM_Module_2%2C%20pwmSignal%2C%201%2C%20kPWM_SignedCenterAligned%2C%20pwmFrequencyInHz%2C%3CBR%20%2F%3E%20pwmSourceClockInHz)%3B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F***********%20PWMA_SM3%20-%20phase%20C%20configuration%2C%20setup%20PWM%20A%20channel%20only%20************%2F%3CBR%20%2F%3E%20PWM_SetupPwm(BOARD_PWM_BASEADDR%2C%20kPWM_Module_3%2C%20pwmSignal%2C%201%2C%20kPWM_SignedCenterAligned%2C%20pwmFrequencyInHz%2C%3CBR%20%2F%3E%20pwmSourceClockInHz)%3B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CBR%20%2F%3E%7D%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F*!%3CBR%20%2F%3E%20*%20%40brief%20Main%20function%3CBR%20%2F%3E%20*%2F%3CBR%20%2F%3Eint%20main(void)%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%20%2F*%20Structure%20of%20initialize%20PWM%20*%2F%3CBR%20%2F%3E%20pwm_config_t%20pwmConfig%3B%3CBR%20%2F%3E%20static%20uint16_t%20delay%3B%3CBR%20%2F%3E%20uint32_t%20pwmVal%20%3D%204%3B%3CBR%20%2F%3E%20uint16_t%20i%3B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F*%20Board%20pin%2C%20clock%2C%20debug%20console%20init%20*%2F%3CBR%20%2F%3E%20BOARD_ConfigMPU()%3B%3CBR%20%2F%3E%20BOARD_InitPins()%3B%3CBR%20%2F%3E%20BOARD_BootClockRUN()%3B%3CBR%20%2F%3E%20BOARD_InitDebugConsole()%3B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3ECLOCK_SetDiv(kCLOCK_AhbDiv%2C%200x2)%3B%20%2F*%20Set%20AHB%20PODF%20to%202%2C%20divide%20by%203%20*%2F%3CBR%20%2F%3E%20CLOCK_SetDiv(kCLOCK_IpgDiv%2C%200x3)%3B%20%2F*%20Set%20IPG%20PODF%20to%203%2C%20divede%20by%204%20*%2F%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F*%20Set%20the%20PWM%20Fault%20inputs%20to%20a%20low%20value%20*%2F%3CBR%20%2F%3E%20XBARA_Init(XBARA1)%3B%3CBR%20%2F%3E%20XBARA_SetSignalsConnection(XBARA1%2C%20kXBARA1_InputLogicHigh%2C%20kXBARA1_OutputFlexpwm1Fault0)%3B%3CBR%20%2F%3E%20XBARA_SetSignalsConnection(XBARA1%2C%20kXBARA1_InputLogicHigh%2C%20kXBARA1_OutputFlexpwm1Fault1)%3B%3CBR%20%2F%3E%20XBARA_SetSignalsConnection(XBARA1%2C%20kXBARA1_InputLogicHigh%2C%20kXBARA1_OutputFlexpwm1234Fault2)%3B%3CBR%20%2F%3E%20XBARA_SetSignalsConnection(XBARA1%2C%20kXBARA1_InputLogicHigh%2C%20kXBARA1_OutputFlexpwm1234Fault3)%3B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3EPRINTF(%22FlexPWM%20driver%20example%5Cn%22)%3B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F*%3CBR%20%2F%3E%20*%20pwmConfig.enableDebugMode%20%3D%20false%3B%3CBR%20%2F%3E%20*%20pwmConfig.enableWait%20%3D%20false%3B%3CBR%20%2F%3E%20*%20pwmConfig.reloadSelect%20%3D%20kPWM_LocalReload%3B%3CBR%20%2F%3E%20*%20pwmConfig.faultFilterCount%20%3D%200%3B%3CBR%20%2F%3E%20*%20pwmConfig.faultFilterPeriod%20%3D%200%3B%3CBR%20%2F%3E%20*%20pwmConfig.clockSource%20%3D%20kPWM_BusClock%3B%3CBR%20%2F%3E%20*%20pwmConfig.prescale%20%3D%20kPWM_Prescale_Divide_1%3B%3CBR%20%2F%3E%20*%20pwmConfig.initializationControl%20%3D%20kPWM_Initialize_LocalSync%3B%3CBR%20%2F%3E%20*%20pwmConfig.forceTrigger%20%3D%20kPWM_Force_Local%3B%3CBR%20%2F%3E%20*%20pwmConfig.reloadFrequency%20%3D%20kPWM_LoadEveryOportunity%3B%3CBR%20%2F%3E%20*%20pwmConfig.reloadLogic%20%3D%20kPWM_ReloadImmediate%3B%3CBR%20%2F%3E%20*%20pwmConfig.pairOperation%20%3D%20kPWM_Independent%3B%3CBR%20%2F%3E%20*%2F%3CBR%20%2F%3E%20PWM_GetDefaultConfig(%26amp%3BpwmConfig)%3B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F*%20Use%20full%20cycle%20reload%20*%2F%3CBR%20%2F%3E%20pwmConfig.reloadLogic%20%3D%20kPWM_ReloadPwmFullCycle%3B%3CBR%20%2F%3E%20%2F*%20PWM%20A%20%26amp%3B%20PWM%20B%20form%20a%20complementary%20PWM%20pair%20*%2F%3CBR%20%2F%3E%20pwmConfig.pairOperation%20%3D%20kPWM_ComplementaryPwmA%3B%3CBR%20%2F%3E%20pwmConfig.enableDebugMode%20%3D%20true%3B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F*%20Initialize%20submodule%200%20*%2F%3CBR%20%2F%3E%20if%20(PWM_Init(BOARD_PWM_BASEADDR%2C%20kPWM_Module_0%2C%20%26amp%3BpwmConfig)%20%3D%3D%20kStatus_Fail)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20PRINTF(%22PWM%20initialization%20failed%5Cn%22)%3B%3CBR%20%2F%3E%20return%201%3B%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F*%20Initialize%20submodule%201%20*%2F%3CBR%20%2F%3E%20pwmConfig.clockSource%20%3D%20kPWM_Submodule0Clock%3B%3CBR%20%2F%3E%20pwmConfig.initializationControl%20%3D%20kPWM_Initialize_MasterSync%3B%3CBR%20%2F%3E%20if%20(PWM_Init(BOARD_PWM_BASEADDR%2C%20kPWM_Module_1%2C%20%26amp%3BpwmConfig)%20%3D%3D%20kStatus_Fail)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20PRINTF(%22PWM%20initialization%20failed%5Cn%22)%3B%3CBR%20%2F%3E%20return%201%3B%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F*%20Initialize%20submodule%202%20the%20same%20way%20as%20submodule%201%20*%2F%3CBR%20%2F%3E%20if%20(PWM_Init(BOARD_PWM_BASEADDR%2C%20kPWM_Module_2%2C%20%26amp%3BpwmConfig)%20%3D%3D%20kStatus_Fail)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20PRINTF(%22PWM%20initialization%20failed%5Cn%22)%3B%3CBR%20%2F%3E%20return%201%3B%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F*%20Initialize%20submodule%203%20the%20same%20way%20as%20submodule%201%20*%2F%3CBR%20%2F%3E%20if%20(PWM_Init(BOARD_PWM_BASEADDR%2C%20kPWM_Module_3%2C%20%26amp%3BpwmConfig)%20%3D%3D%20kStatus_Fail)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20PRINTF(%22PWM%20initialization%20failed%5Cn%22)%3B%3CBR%20%2F%3E%20return%201%3B%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3CBR%20%2F%3E%20%2F*%20Call%20the%20init%20function%20with%20demo%20configuration%20*%2F%3CBR%20%2F%3E%20PWM_DRV_Init3PhPwm()%3B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F*%20Set%20the%20load%20okay%20bit%20for%20all%20submodules%20to%20load%20registers%20from%20their%20buffer%20*%2F%3CBR%20%2F%3E%20PWM_SetPwmLdok(BOARD_PWM_BASEADDR%2C%20kPWM_Control_Module_0%20%7C%20kPWM_Control_Module_1%20%7C%20kPWM_Control_Module_2%20%7C%20kPWM_Control_Module_3%2C%20true)%3B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F*%20Start%20the%20PWM%20generation%20from%20Submodules%200%2C%201%20and%202%20*%2F%3CBR%20%2F%3E%20PWM_StartTimer(BOARD_PWM_BASEADDR%2C%20kPWM_Control_Module_0%20%7C%20kPWM_Control_Module_1%20%7C%20kPWM_Control_Module_2%20%7C%20kPWM_Control_Module_3)%3B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3Edelay%20%3D%200x0fffU%3B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3Ewhile%20(1U)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20for%20(i%20%3D%200U%3B%20i%20%26lt%3B%20delay%3B%20i%2B%2B)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20__ASM%20volatile(%22nop%22)%3B%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20pwmVal%20%3D%20pwmVal%20%2B%204%3B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F*%20Reset%20the%20duty%20cycle%20percentage%20*%2F%3CBR%20%2F%3E%20if%20(pwmVal%20%26gt%3B%20100)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20pwmVal%20%3D%204%3B%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F*%20Update%20duty%20cycles%20for%20all%203%20PWM%20signals%20*%2F%3CBR%20%2F%3E%20PWM_UpdatePwmDutycycle(BOARD_PWM_BASEADDR%2C%20kPWM_Module_0%2C%20kPWM_PwmA%2C%20kPWM_SignedCenterAligned%2C%20pwmVal)%3B%3CBR%20%2F%3E%20PWM_UpdatePwmDutycycle(BOARD_PWM_BASEADDR%2C%20kPWM_Module_1%2C%20kPWM_PwmA%2C%20kPWM_SignedCenterAligned%2C%20(pwmVal%20%26gt%3B%26gt%3B%201))%3B%3CBR%20%2F%3E%20PWM_UpdatePwmDutycycle(BOARD_PWM_BASEADDR%2C%20kPWM_Module_2%2C%20kPWM_PwmA%2C%20kPWM_SignedCenterAligned%2C%20(pwmVal%20%26gt%3B%26gt%3B%202))%3B%3CBR%20%2F%3E%20PWM_UpdatePwmDutycycle(BOARD_PWM_BASEADDR%2C%20kPWM_Module_3%2C%20kPWM_PwmA%2C%20kPWM_SignedCenterAligned%2C%20(pwmVal%20%26gt%3B%26gt%3B%203))%3B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%2F*%20Set%20the%20load%20okay%20bit%20for%20all%20submodules%20to%20load%20registers%20from%20their%20buffer%20*%2F%3CBR%20%2F%3E%20PWM_SetPwmLdok(BOARD_PWM_BASEADDR%2C%20kPWM_Control_Module_0%20%7C%20kPWM_Control_Module_1%20%7C%20kPWM_Control_Module_2%20%7C%20kPWM_Control_Module_3%2C%20true)%3B%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%7D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-998322%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MIMXRT1060-EVK%20backlight%20control%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-998322%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3EThere%20is%20no%20direct%20backlight%20demo.%20In%20all%20lcd%20demo%2C%20GPIO_B1_15%20works%20as%20gpio.%20In%20backlight%20circuit%2C%20UM1661%20support%20PWM%20dimming%20control.%20Please%20refer%20to%20the%20PWM%20demo%20in%20SDK.%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3ERegards%2C%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3EJing%3C%2FP%3E%3C%2FLINGO-BODY%3E
