MIMXRT1010 help
MIMXRT1010 help
1,807 次查看
LuigiV
I'm developing a new project using the MIMXRT1010 processor and it is the first time I use this type of crossover MCU; where can I find more information about the hardware implementation (schematic, application note,...) ?
Thank you
Luigi
4 回复数
1,796 次查看
_angelo_
just a simple google search,
https://www.nxp.com/design/development-boards/i-mx-evaluation-and-development-boards/i-mx-rt1010-eva...
https://www.nxp.com/products/processors-and-microcontrollers/arm-microcontrollers/i-mx-rt-crossover-...
It's based on Cortex M technology, that can be studied as a base on  more generic documentation spread all around the web from ARM.
1,772 次查看
LuigiV
Thank you,
but does exist a way to have a documentation about the routines used in the examples ?
I need to interface an external codec to the I2S, I've found tha SAI project but no documentation that explains the routines synthax and all the several parameters they use; I2S, DMA,...
1,762 次查看
RaRo
Hello @LuigiV,
Just for double check, could you please take a look to the API Reference Manual? There is explained a little bit more about the SAI driver. You could look for the API Reference Manual in docs inside the SDK.
Also, it might be useful to take a look to Emulating I2S Bus with the FlexIO on RT1010.
Kind regards, Raul.
1,745 次查看
LuigiV
Thank you Raul,
I've downloaded the document and I'll take a look to the API...
Best regards, Luigi
