MIMX8UX5CVLFZAC
MIMX8UX5CVLFZAC
3,898 次查看
Mohan1
Dear Team,
I am Planning to use this part one of my application based cost cost perspective, so I have following query related to this part -MIMX8UX5CVLFZAC
1-This MIMX8UX5CVLFZAC part will support 32bit DDR3 ?
2-Is there any option to connect the parallel MRAM(16bit) with external memory interface ?
Mohan M
8 回复数
3,890 次查看
Bio_TICFSL
Hello Mohan1,
1. Its support to connect DDR3L could be 32 or 64 bit.
2. No there is no option to connect MRAM
3,880 次查看
Mohan1
Dear Team,
Thanks for the reply
In page no#5,8 &,49 mentioned liks this, The SDRAM controller will support only 16bit DDR3L & LPDDR4.Also there is no dedicated pin availabe in pin configuration table -Page#124.
"• Memory types: LPDDR4and DDR3L
• One channel of 16-bit memory:
• LPDDR4 up to 1.2 GHz
• DDR3L up to 933MHz "
I am referring the datasheet " Document Number: IMX8DXIEC
Rev. 0, 05/2020" Please confirm the same.
Mohan M
标记 (1)
3,875 次查看
Bio_TICFSL
Yes, sorry is only one channel for 16bit.
3,872 次查看
Mohan1
Dear Team,
Thank for the reply,
can you please let me know, Is there any alternate part with this specification& same cost.
Mohan M
3,846 次查看
Mohan1
Dear team,
Thanks for your reply,
I have some additional query in below, can you please support.
1- Maximum memory supported by SDRAM controller (MIMX8UX5CVLFZAC)  - DDR3L & DDR4
Mohan M
3,819 次查看
Mohan1
Do you have evaluation board with MIMX8UX5CVLFZAC-part?
Mohan M
3,806 次查看
Bio_TICFSL
We have the EVB for the Quad version https://www.nxp.com/design/development-boards/i-mx-evaluation-and-development-boards/i-mx-8quadxplus...
but is works  for Dual as well.
regards
3,797 次查看
Mohan1
Hello Team,
Thanks for the reply,
The Quad version board have any chip socket to replace the dualx Chip?
I have found the Dualx board part number  : MCIMX8DX-CPU but there is no stock in NXP and distributors. MCIMX8DX-CPU Product Information|NXP
Maximum memory supported by SDRAM controller (MIMX8UX5CVLFZAC)  - DDR3L & DDR4 ?
Mohan M
