MFG tools problem
MFG tools problem
4,093 次查看
marshall123
Hello, I have difficulty flashing the SD card with MFG tool. When I connect the usb otg port to the computer, the computer didn't recongnize it as HID device but recongnize it as usb portable device, then I open the MFG tool and MFG tool recongnize it as Virtual HID Minidriver Collection. then I press start and the MFG tool says <"Boot" body="BootStrap" error, file="C:\Users\qian060\Downloads\mfg_tools\mfgtools\Profiles\linux\OS Firmware\firmware\u-boot-imx6qpsabresd_sd.imx">  and the download process just stopped. Can you tell me how to solve the problem?
标签 (1)
4 回复数
3,904 次查看
Rita_Wang
If you design the board yourself, and use the different DDR with the reference board. You need to configure the DDR first and porting the BSP, rebuild the images for mfgtool.
Dan
Note: If this post answers your question, please click the Mark Correct button. Thank you!
3,904 次查看
marshall123
nope, I used the i.mx6qp sabre sd board. I solved the problem by reinstalling windows!
3,904 次查看
Rita_Wang
I am very glad you have solved the mfgtool problem. I though you were using the board you designed yourself. Here you are using the board from our company, so you just need to follow our user guide documents, and them will help you. Welcome to create new thread in our community if you have new questions.
Have a nice day
Dan
3,904 次查看
Rita_Wang
Here which board are you using? The reference board or you design the board yourself? Which version BSP are you using?
Have a nice day
Dan
