MFG tool
MFG tool
ratnakar_vibhu1
Hi Team,
From where we can get the MFG tool for Imx8qm.
Also how to use the same for the mass production?
shivanipatel
Senior Contributor II
Hi, ratnakar vibhute‌
You can get the MFGTool for i.MX8mq from this link.
To flash multiple devices at the same time using MFGTool, you need to modify UICfg.ini file.
In this file, PortMgrDlg variable indicates how many boards can be supported simultaneously. By default PortMgrDlg=1, but it can support up to four boards.
So, PortMgrDlg can be set to 1-4.
Shivani Patel
joanxie
for imx8qm, I think you should use UUU tools, you can download the demo image which includes the uuu tool
