MFG Tool: modifiy source code to program 9 iMX6 at a time
1,394 次查看
romainheslouin
I need to use MFG tool  to program  an eMMC via the IMX6. Those eMMC are soldered on 9 different boards (each one have an iMX6) and I want to program them in parallel.
How can I modify the MFG tool code to be able to program more than 4 boards in parallel?
Thanks in advance.
1,312 次查看
joanxie
pls refer to the document named " Manufacturing Tool V2(MFGTool2) Factory Operation Manual" , you can find this document in the mfgtool package.path is mfgtools>Document>v2
