MCUxpresso: FreeRTOS task and queue list windows empty
1,239件の閲覧回数
davenadler
Senior Contributor II
Problem:
The IDE FreeRTOS-aware windows do not display anything.
At one time this worked fine, and now going back to it a year later nothing shows up.
Context:
  • large FreeRTOS application running on imxRT1024.
  • debug build
  • paused debugger after scheduler is running
  • debugger is working fine, showing all threads (tasks)
  • MCUXpresso IDE v24.9 [Build 25] [2024-09-26] on Windows 10
  • segger J-Link software version V8.12
  • freertos_tasks_c_additions.h added from SDK_2_15_000_MIMXRT1024xxxxx
    also added  __attribute__((used)) to FreeRTOSDebugConfig[] to ensure loading
  • debugger reads FreeRTOSDebugConfig[24] just fine (note size 24)
  • FreeRTOSConfig.h includes:
    #define configINCLUDE_FREERTOS_TASK_C_ADDITIONS_H 1 // DRN: may be required for FreeRTOS-aware debugger windows??
    #define configGENERATE_RUN_TIME_STATS 0
    #define configUSE_TRACE_FACILITY 1 // legacy trace, prerequisite for configUSE_TRACE_FACILITY
    #define configUSE_STATS_FORMATTING_FUNCTIONS 1 // DRN: may be required for FreeRTOS-aware debugger windows??
  • Arm GNU Toolchain 13.2.rel1 (Build arm-13.7)) 13.2.1 20231009
  • JLink debugger configuration enables FreeRTOS:
Any help would be greatly appreciated!
Best Regards, Dave
1,186件の閲覧回数
davenadler
I got this working by upgrading to SEGGER J-Link V9.22 software.
As always it takes a couple of tries to get something into the FreeRTOS-aware windows (long-standing MCUxpresso bug).
Contrary to some documentation on this site, at least for Segger the freertos_tasks_c_additions.h file is not required.
The relevant FreeRTOSCOnfig settings I'm now using are:
/* Run time and task stats gathering related definitions. */
#define configINCLUDE_FREERTOS_TASK_C_ADDITIONS_H  0 // DRN: NOT required for FreeRTOS-aware debugger windows??
#define configUSE_TRACE_FACILITY               0 // DRN: NOT required for FreeRTOS-aware debugger windows, prerequisite for vTaskList(), vTaskGetRunTimeStats(), etc.
#define configUSE_STATS_FORMATTING_FUNCTIONS   0 // DRN: NOT required for FreeRTOS-aware debugger windows
#define configENABLE_BACKWARD_COMPATIBILITY     1
1,187件の閲覧回数
davenadler
1,211件の閲覧回数
mayliu1
Hi @davenadler ,
Thank you so much for your interest in our products and for using our community.
First, I recommend referring to the MCUXpresso IDE FreeRTOS Debug Guide for detailed requirements and configuration steps:
https://www.nxp.com/webapp/Download?colCode=UG10059&appType=license&location=null
Second, regarding your issue, please try the following actions to address the likely root cause:
1: Set configENABLE_BACKWARD_COMPATIBILITY to 0 in FreeRTOSConfig.h
A similar case was reported in the NXP Community, where setting this macro to 0 resolved the problem of an empty FreeRTOS Task List.
Please apply the same fix to test whether it resolves your issue.
Solved: Freertos debug issue - NXP Community
2: Follow the configuration described in Section 4.2 (SEGGER J‑Link probes) of the MCUXpresso IDE 25.06 FreeRTOS Debug Guide
FreeRTOS thread-aware debugging for SEGGER J‑Link is disabled by default, and you must explicitly enable the RTOS plug‑in (GDBServer/RTOSPlugin_FreeRTOS) in your J‑Link Launch Configuration.
Wish it helps you
Best Regards
MayLiu
%3CLINGO-SUB%20id%3D%22lingo-sub-2325236%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMCUxpresso%3A%20FreeRTOS%20%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%A8%E3%82%AD%E3%83%A5%E3%83%BC%E3%83%AA%E3%82%B9%E3%83%88%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%81%8C%E7%A9%BA%E3%81%A7%E3%81%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2325236%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSTRONG%3E%E5%95%8F%E9%A1%8C%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EIDE%20FreeRTOS%20%E5%AF%BE%E5%BF%9C%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%81%AB%E3%81%AF%E4%BD%95%E3%82%82%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%E3%81%8B%E3%81%A4%E3%81%A6%E3%81%AF%E3%81%93%E3%82%8C%E3%81%A7%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%811%E5%B9%B4%E5%BE%8C%E3%81%AB%E3%81%93%E3%81%AE%E7%8A%B6%E6%85%8B%E3%81%AB%E6%88%BB%E3%82%8B%E3%81%A8%E4%BD%95%E3%82%82%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%82%B3%E3%83%B3%E3%83%86%E3%82%AF%E3%82%B9%E3%83%88%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3EimxRT1024%20%E4%B8%8A%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%82%8B%E5%A4%A7%E8%A6%8F%E6%A8%A1%E3%81%AA%20FreeRTOS%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%80%82%3C%2FLI%3E%3CLI%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%93%E3%83%AB%E3%83%89%3C%2FLI%3E%3CLI%3E%E3%82%B9%E3%82%B1%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%A9%E3%81%AE%E5%AE%9F%E8%A1%8C%3CSTRONG%3E%3CU%3E%E5%BE%8C%E3%81%AB%3C%2FU%3E%3C%2FSTRONG%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%82%92%E4%B8%80%E6%99%82%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FLI%3E%3CLI%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%EF%BC%88%E3%82%BF%E3%82%B9%E3%82%AF%EF%BC%89%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FLI%3E%3CLI%3EMCUXpresso%20IDE%20v24.9%20%5B%E3%83%93%E3%83%AB%E3%83%89%2025%5D%20%5B2024-09-26%5D%20(Windows%2010%20%E7%89%88)%3C%2FLI%3E%3CLI%3E%E3%82%BB%E3%82%AC%E3%83%BC%20J-Link%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%20V8.12%3C%2FLI%3E%3CLI%3Efreertos_tasks_c_additions.h%20%E3%81%8C%20SDK_2_15_000_MIMXRT1024xxxxx%20%E3%81%8B%E3%82%89%E8%BF%BD%E5%8A%A0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EFreeRTOSDebugConfig%5B%5D%E3%81%AB__attribute__%20%EF%BC%88%EF%BC%88used%EF%BC%89%EF%BC%89%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FLI%3E%3CLI%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%81%AFFreeRTOSDebugConfig%5B24%5D%E3%82%92%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%EF%BC%88%E3%82%B5%E3%82%A4%E3%82%BA24%E3%81%AB%E6%B3%A8%E6%84%8F%EF%BC%89%3C%2FLI%3E%3CLI%3EFreeRTOSConfig.h%20%E3%81%AB%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%223%22%3E%23define%20configINCLUDE_FREERTOS_TASK_C_ADDITIONS_H%201%20%2F%2F%20DRN%3A%20FreeRTOS%20%E5%AF%BE%E5%BF%9C%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%20%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AB%E3%81%AA%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%223%22%3E%23define%20configGENERATE_RUN_TIME_STATS%200%3C%2FFONT%3E%3CBR%20%2F%3E%20%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%223%22%3E%23define%20configUSE_TRACE_FACILITY%201%20%2F%2F%20%E3%83%AC%E3%82%AC%E3%82%B7%E3%83%BC%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%E3%80%81configUSE_TRACE_FACILITY%E3%81%AE%E5%89%8D%E6%8F%90%E6%9D%A1%E4%BB%B6%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%20size%3D%223%22%3E%23define%20configUSE_STATS_FORMATTING_FUNCTIONS%201%20%2F%2F%20DRN%3A%20FreeRTOS%20%E5%AF%BE%E5%BF%9C%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%20%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AB%E3%81%AA%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FFONT%3E%3C%2FLI%3E%3CLI%3EArm%20GNU%20%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%2013.2.rel1%EF%BC%88%E3%83%93%E3%83%AB%E3%83%89arm-13.7%EF%BC%8913.2.1%2020231009%3C%2FLI%3E%3CLI%3EJLink%20%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%E6%A7%8B%E6%88%90%E3%81%AB%E3%82%88%E3%82%8A%20FreeRTOS%20%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22JLink_debug_cfg.PNG%22%20style%3D%22width%3A%20975px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JLink_debug_cfg.PNG%22%20style%3D%22width%3A%20975px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F378131i687CECEB4DD75AAD%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22JLink_debug_cfg.PNG%22%20alt%3D%22JLink_debug_cfg.PNG%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EJLink_debug_cfg.PNG%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E3%81%A9%E3%81%AA%E3%81%9F%E3%81%8B%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99!%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%E3%83%87%E3%82%A4%E3%83%96%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2325236%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%20RT%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2325839%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCUxpresso%3A%20FreeRTOS%20task%20and%20queue%20list%20windows%20empty%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2325839%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ESEGGER%20J-Link%20V9.22%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E3%82%A2%E3%83%83%E3%83%97%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81%E3%81%93%E3%82%8C%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%81%84%E3%81%A4%E3%82%82%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%80%81FreeRTOS%20%E5%AF%BE%E5%BF%9C%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%81%AB%E4%BD%95%E3%81%8B%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E6%95%B0%E5%9B%9E%E3%81%AE%E8%A9%A6%E8%A1%8C%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%20(%E9%95%B7%E5%B9%B4%E3%81%AE%20MCUxpresso%20%E3%81%AE%E3%83%90%E3%82%B0)%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%82%B5%E3%82%A4%E3%83%88%E3%81%AE%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%A8%E3%81%AF%E5%AF%BE%E7%85%A7%E7%9A%84%E3%81%AB%E3%80%81%E5%B0%91%E3%81%AA%E3%81%8F%E3%81%A8%E3%82%82Segger%E3%81%AE%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Efreertos_tasks_c_additions.h%3C%2FFONT%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E5%BF%85%E8%A6%81%3CEM%3E%3CU%3E%3CSTRONG%3E%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSTRONG%3E%3C%2FU%3E%3C%2FEM%3E%E3%80%82%3CBR%20%2F%3E%E7%8F%BE%E5%9C%A8%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%20FreeRTOSCONfig%20%E8%A8%AD%E5%AE%9A%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-cpp%22%3E%3CCODE%20translate%3D%22no%22%3E%2F*%20Run%20time%20and%20task%20stats%20gathering%20related%20definitions.%20*%2F%0A%23define%20configINCLUDE_FREERTOS_TASK_C_ADDITIONS_H%20%200%20%2F%2F%20DRN%3A%20NOT%20required%20for%20FreeRTOS-aware%20debugger%20windows%3F%3F%0A%23define%20configGENERATE_RUN_TIME_STATS%20%20%20%20%20%20%20%20%20%200%0A%23define%20configUSE_TRACE_FACILITY%20%20%20%20%20%20%20%20%20%20%20%20%20%20%200%20%2F%2F%20DRN%3A%20NOT%20required%20for%20FreeRTOS-aware%20debugger%20windows%2C%20prerequisite%20for%20vTaskList()%2C%20vTaskGetRunTimeStats()%2C%20etc.%0A%23define%20configUSE_STATS_FORMATTING_FUNCTIONS%20%20%200%20%2F%2F%20DRN%3A%20NOT%20required%20for%20FreeRTOS-aware%20debugger%20windows%0A%23define%20configENABLE_BACKWARD_COMPATIBILITY%20%20%20%20%201%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2325321%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCUxpresso%3A%20FreeRTOS%20task%20and%20queue%20list%20windows%20empty%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2325321%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F132425%22%20target%3D%22_blank%22%3E%40davenadler%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CP%3E%E5%BC%8A%E7%A4%BE%E3%81%AE%E8%A3%BD%E5%93%81%E3%81%AB%E3%81%94%E8%88%88%E5%91%B3%E3%82%92%E3%81%8A%E6%8C%81%E3%81%A1%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E3%81%BE%E3%81%9F%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%82%92%E3%81%94%E5%88%A9%E7%94%A8%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E8%AA%A0%E3%81%AB%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CDIV%3E%E3%81%BE%E3%81%9A%E3%80%81%E8%A9%B3%E7%B4%B0%E3%81%AA%E8%A6%81%E4%BB%B6%E3%81%A8%E6%A7%8B%E6%88%90%E6%89%8B%E9%A0%86%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81MCUXpresso%20IDE%20FreeRTOS%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%AC%E3%82%A4%E3%83%89%E3%82%92%E5%8F%82%E7%85%A7%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DUG10059%26amp%3BappType%3Dlicense%26amp%3Blocation%3Dnull%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DUG10059%26amp%3BappType%3Dlicense%26amp%3Blocation%3Dnull%3C%2FA%3E%3C%2FP%3E%0A%3CDIV%3E%E6%AC%A1%E3%81%AB%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E3%80%81%E8%80%83%E3%81%88%E3%82%89%E3%82%8C%E3%82%8B%E6%A0%B9%E6%9C%AC%E5%8E%9F%E5%9B%A0%E3%81%AB%E5%AF%BE%E5%87%A6%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E6%AC%A1%E3%81%AE%E6%93%8D%E4%BD%9C%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FDIV%3E%0A%3CP%3E1%3A%20FreeRTOSConfig.h%20%E3%81%A7%20configENABLE_BACKWARD_COMPATIBILITY%20%E3%82%92%200%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%3C%2FP%3E%0A%3CDIV%3E%0A%3CP%3ENXP%20%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%A7%E3%82%82%E5%90%8C%E6%A7%98%E3%81%AE%E3%82%B1%E3%83%BC%E3%82%B9%E3%81%8C%E5%A0%B1%E5%91%8A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%81%93%E3%81%AE%E3%83%9E%E3%82%AF%E3%83%AD%E3%82%92%200%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81FreeRTOS%20%E3%82%BF%E3%82%B9%E3%82%AF%20%E3%83%AA%E3%82%B9%E3%83%88%E3%81%8C%E7%A9%BA%E3%81%AB%E3%81%AA%E3%82%8B%E5%95%8F%E9%A1%8C%E3%81%8C%E8%A7%A3%E6%B1%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E5%90%8C%E3%81%98%E4%BF%AE%E6%AD%A3%E3%82%92%E9%81%A9%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%8C%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3C%2FDIV%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FMCUXpresso-IDE%2FFreertos-debug-issue%2Fm-p%2F1403312%22%20target%3D%22_blank%22%3E%E8%A7%A3%E6%B1%BA%E6%B8%88%E3%81%BF%3A%20Freertos%20%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E5%95%8F%E9%A1%8C%20-%20NXP%20%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%3C%2FA%3E%3C%2FP%3E%0A%3CDIV%3E%0A%3CP%3E2%3A%20MCUXpresso%20IDE%2025.06%20FreeRTOS%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B34.2%EF%BC%88SEGGER%20J-Link%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%EF%BC%89%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E6%A7%8B%E6%88%90%E3%81%AB%E5%BE%93%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CDIV%3E%0A%3CP%3ESEGGER%20J%E2%80%91Link%20%E3%81%AE%20FreeRTOS%20%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E5%AF%BE%E5%BF%9C%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%AF%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81J%E2%80%91Link%20%E8%B5%B7%E5%8B%95%E6%A7%8B%E6%88%90%E3%81%A7%20RTOS%20%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%20(GDBServer%2FRTOSPlugin_FreeRTOS)%20%E3%82%92%E6%98%8E%E7%A4%BA%E7%9A%84%E3%81%AB%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3C%2FDIV%3E%0A%3CP%3E%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%A1%E3%82%A4%E3%83%AA%E3%83%A5%E3%83%BC%3C%2FP%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
