Looking for LPDDR4 DRAM Pin-to-Pin Compatible with NXP i.MX8M Quad (MIMX8MQ6DVAJZAB)
ak_r_h
I am currently working on a SoM - System on Module utilizing the NXP i.MX8M Quad processor (part number: MIMX8MQ6DVAJZAB) and am seeking recommendations for an LPDDR4 DRAM component that meets the following criteria:
  • Pin-to-pin compatibility with the MIMX8MQ6DVAJZAB
  • Operating frequency: 1866 MHz (~ 3733 MT/s data rate)
  • Operating Voltage : 1.1 V, 1.25 V, or 1.33 V
  • Density: Preferably available in 16 Gb or 32 Gb configurations
If you have experience with specific DRAM parts that are validated or widely used in conjunction with the MIMX8MQ6DVAJZAB, I would greatly appreciate your recommendations or insights.
Thank you in advance!
Rita_Wang
You can consider  MT53E1G32D2FW-046 and K4GBE3D4HM for 4GB.
ak_r_h
MT53E1G32D2FW-046 is scheduled for obsolescence and i can't find its datasheet.
The datasheet for part number K4GBE3D4HM is not available but i did find another part number K4FBE3D4HM-MGCJ.
Can i proceed with this part number(K4FBE3D4HM-MGCJ)?
Rita_Wang
You can use it, and you can see the validation the DDR on the i.MX8MQ:
I found the link, it will do help for you:
i.MX 8M Quad/Mini/Nano/Plus - LPDDR4, DDR4 & DDR3L memory compatibility guide - NXP Community
Wish you have a nice day
Best Regards
Rita
%3CLINGO-SUB%20id%3D%22lingo-sub-2158152%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELooking%20for%20LPDDR4%20DRAM%20Pin-to-Pin%20Compatible%20with%20NXP%20i.MX8M%20Quad%20(MIMX8MQ6DVAJZAB)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2158152%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EI%20am%20currently%20working%20on%20a%20%3CSTRONG%3ESoM%20-%20System%20on%20Module%3C%2FSTRONG%3E%20utilizing%20the%20NXP%20i.MX8M%20Quad%20processor%20(part%20number%3A%20%3CSTRONG%3EMIMX8MQ6DVAJZAB%3C%2FSTRONG%3E)%20and%20am%20seeking%20recommendations%20for%20an%20%3CSTRONG%3ELPDDR4%20DRAM%20component%3C%2FSTRONG%3E%20that%20meets%20the%20following%20criteria%3A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%3CSTRONG%3EPin-to-pin%20compatibility%3C%2FSTRONG%3E%20with%20the%26nbsp%3B%3CSTRONG%3EMIMX8MQ6DVAJZAB%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3EOperating%20frequency%3A%3C%2FSTRONG%3E%201866%20MHz%20(~%203733%20MT%2Fs%20data%20rate)%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3EOperating%20Voltage%20%3A%3C%2FSTRONG%3E%201.1%20V%2C%201.25%20V%2C%20or%201.33%20V%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3EDensity%3A%3C%2FSTRONG%3E%20Preferably%20available%20in%2016%20Gb%20or%2032%20Gb%20configurations%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3EIf%20you%20have%20experience%20with%20specific%20DRAM%20parts%20that%20are%20validated%20or%20widely%20used%20in%20conjunction%20with%20the%20MIMX8MQ6DVAJZAB%2C%20I%20would%20greatly%20appreciate%20your%20recommendations%20or%20insights.%3C%2FP%3E%3CP%3EThank%20you%20in%20advance!%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2158152%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208%20Family%20%7C%20i.MX%208QuadMax%20(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
