ADV7535: No image output on display
1,328 次查看
rkathar
Junior Contributor I
Hi Team,
We are working on DSI to HDMI converter (ADV7535) on our custom carrier board, which is based on Verdin Yavia IMX8M Plus. We have replaced ADV7535 instead of LT8912B MIPI DSI to HDMI bridge, which comes with Toradex carrier board.  We are using I2C channel 2 to communicate with the ADV7535 DSI to HDMI bridge, unlike the Yavia Carrier Board which uses a different I2C channel. As a result, we have made the following updates to the device tree to reflect this change:
 rkathar_0-1753091144426.pngDevice Tree Changes
1. verdin-imx8mp_dsi-to-hdmi_overlay.dts
  • Removed the existing hdmi_lontium_lt8912 node.
  • Added a new hdmi_adv7535 node under the I2C2 node.
2. imx8mp-verdin.dtsi
  • Removed the hdmi_lontium_lt8912 node.
  • Removed Lontium pin connection details from the hdmi_connector node.
  • Added hdmi_adv7535 as a child node under I2C2.
rkathar_1-1753091144431.png Observed Results After Changes
  1. Successfully able to read/write internal registers of ADV7535.
    1. Able to dump I2C data:
      torizon@verdin-imx8mp-15404184:~$ i2cdump -y -f 1 0x39
      No size specified (using byte-data access)
           0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f    0123456789abcdef
      00: 14 00 00 00 00 00 00 00 00 00 41 0e bc 18 01 13    ?.........A?????
      10: 25 37 00 00 00 00 38 00 46 62 04 a8 00 00 1c 84    %7....8.Fb??..??
      20: 1c bf 04 a8 1e 70 02 1e 00 00 04 a8 08 12 1b ac    ?????p??..??????
      30: 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 b0    ...........?...?
      40: 00 50 f0 76 10 68 68 68 68 00 80 00 00 00 00 00    .P?v?hhhh.?.....
      50: 00 00 02 0d 6d 02 00 00 00 00 00 00 00 00 00 00    ..??m?..........
      60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
      70: 01 0a 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ??..............
      80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
      90: 00 00 00 00 c0 00 40 00 03 02 e0 18 30 61 00 00    ....?.@.????0a..
      a0: 00 00 a4 a4 08 04 00 00 00 00 00 40 00 00 40 14    ..????.....@..@?
      b0: 00 00 00 00 00 00 00 00 00 00 10 00 00 00 00 00    ..........?.....
      c0: 00 00 00 00 00 00 06 00 00 03 00 00 02 00 01 04    ......?..?..?.??
      d0: 0c ff 80 80 80 00 00 00 00 00 00 00 00 00 88 01    ?.???.........??
      e0: d0 70 01 00 00 00 fd 00 00 00 52 46 00 00 00 00    ?p?...?...RF....
      f0: 95 04 ff 00 00 00 00 00 00 00 7d aa 1c 00 b0 00    ??........}??.?.
      1. HDMI display is detected and EDID data is retrieved on the i.MX8MP. While HDMI-A -1 is DSI to HDMI and HDMI-A-2 is native HDMI port.
      root@verdin-imx8mp-15288064:/home/torizon# cat /sys/class/drm/card0-HDMI-A-1/edid | edid-decode
      edid-decode (hex):
      00 ff ff ff ff ff ff 00 30 ae 86 10 01 01 01 01
      22 15 01 03 80 29 1a 78 ee e5 b5 a3 55 49 99 27
      13 50 54 af ef 00 61 40 81 c0 81 80 81 8a 81 90
      95 00 95 0f 01 01 64 19 00 40 41 00 26 30 18 88
      36 00 a0 1d 00 00 00 18 00 00 00 fc 00 4c 45 4e
      20 4c 31 39 35 30 77 44 0a 20 00 00 00 fd 00 32
      4c 1e 51 0e 00 0a 20 20 20 20 20 20 00 00 00 ff
      00 42 33 34 33 32 38 34 35 0a 20 20 20 20 01 0b
      02 03 21 71 4e 06 07 02 03 15 96 11 12 13 04 14
      05 1f 90 23 09 07 07 83 01 00 00 65 03 0c 00 10
      00 8c 0a d0 90 20 40 31 20 0c 40 55 00 b9 88 21
      00 00 18 01 1d 80 18 71 1c 16 20 58 2c 25 00 b9
      88 21 00 00 9e 01 1d 80 d0 72 1c 16 20 10 2c 25
      80 b9 88 21 00 00 9e 01 1d 00 bc 52 d0 1e 20 b8
      28 55 40 b9 88 21 00 00 1e 02 3a 80 d0 72 38 2d
      40 10 2c 45 80 b9 88 21 00 00 1e 00 00 00 00 d0
      rkathar_4-1753091284695.png Issues Encountered
      1. No image output on the connected HDMI display.
      2. dmesg log error:
        imx_sec_dsim_drv 32e60000.mipi_dsi: failed to get pmsk for: fin = 12000, fout = 0
      rkathar_5-1753091284691.png Troubleshooting Attempt
      We attempted to modify the MIPI DSI controller clock settings in the device tree as follows:
      mipi_dsi: mipi_dsi@32e60000 {
      				#address-cells = <1>;
      				#size-cells = <0>;
      				compatible = "fsl,imx8mp-mipi-dsim";
      				reg = <0x32e60000 0x10000>;
      				clocks = <&media_blk_ctrl IMX8MP_CLK_MEDIA_BLK_CTRL_MIPI_DSI_PCLK>,
      					 <&media_blk_ctrl IMX8MP_CLK_MEDIA_BLK_CTRL_MIPI_DSI_CLKREF>;
      				clock-names = "cfg", "pll-ref";
      				assigned-clocks = <&clk IMX8MP_CLK_MEDIA_MIPI_PHY1_REF>;
      				assigned-clock-parents = <&clk IMX8MP_CLK_24M>;
      				assigned-clock-rates = <11000000>;
      				interrupts = <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>;
      				power-domains = <&mipi_phy1_pd>;
      				status = "disabled";
      				port@0 {
      					dsim_from_lcdif: endpoint {
      						remote-endpoint = <&lcdif_to_dsim>;
      However, the default frequency still shows as 12 MHz in the dmesg logs.
      rkathar_6-1753091284693.png Request for Clarification
      We would appreciate your guidance on the following points:
      1. How can we correctly update the fin and fout values to resolve the pmsk error?
      2. Are there any additional device tree changes required to enable proper image output via ADV7535?
      Looking forward to your insights and suggestions.
      Please see attached dmesg log, device tree overlay into this thread.
      Thanks & Regards,
      Rupesh Kathar
      IMX8MPLUS #ADV7535 #DSI #HDMI #MIPI #I2C #I2S
标签 (1)
5 回复数
1,294 次查看
joanxie
it seems this error message is from your own driver, I didn't find this from nxp driver source code, and this settings isn't correct, you couldn't get any clock what you want, the clock parent is 24Mhz,  if you set 11Mhz, you only can get 24/2=12Mhz,
 you can refer to the nxp source code for reference, check your settings about lcdif, mipi dsi and adv7535 are correct or not
linux-imx/arch/arm64/boot/dts/freescale/imx8mp-evk.dts at lf-6.12.y · nxp-imx/linux-imx · GitHub
linux-imx/arch/arm64/boot/dts/freescale/imx8mp.dtsi at lf-6.12.y · nxp-imx/linux-imx · GitHub
refer to the log, it seems the pll settings isn't correct, the pll driver is under
linux-imx/drivers/gpu/drm/imx/sec_mipi_pll_1432x.h at lf-6.12.y · nxp-imx/linux-imx · GitHub
you can double check it
1,187 次查看
sgour
Hi @joanxie ,
FYR, We are on a custom carrier board similar to Yavia carrier board of Toradex. Only change being the lontium DSI to HDMI adaptor being replaced with ADV7535. We went with ADV7535 as it is also used by NXP in some of its products.
Therefore, we have done device tree modifications on top of Toradex's provided device trees for Yavia-wifi dts and its parent device tree sources.
The device tree nodes is question are
1. Mipi-dsi  - Haven't modified anything here(changed back to default unlike previous post).  It must be used by other NXP devices as well.
2. The ADV7535 specific nodes and overlays, what we have provided in prev post.
The drivers are sec_mipi_dsim-imx.c , sec-dsim.c , adv7511_drv.c , adv7533.c .
Now, after tweaking the device tree overlay. We are not getting the fin, fout error anymore.
Here are the dev_dbg logs from the above drivers.
torizon@verdin-imx8mp-15404184:~$ dmesg | grep drm
[ 0.000000] Kernel command line: root=LABEL=otaroot rootfstype=ext4 quiet logo.nologo vt.global_cursor_defau lt=0 plymouth.ignore-serial-consoles splash fbcon=map:3 ostree=/ostree/boot.1/torizon/7b778d635701b4e0bbc49652c 421a587ae63ff3c6cbfc07d964084a23df7631d/0
[ 2.771129] imx-drm display-subsystem: bound imx-lcdifv3-crtc.0 (ops lcdifv3_crtc_ops)
[ 2.771181] imx-drm display-subsystem: bound imx-lcdifv3-crtc.1 (ops lcdifv3_crtc_ops)
[ 2.772099] imx-drm display-subsystem: bound 32e60000.mipi_dsi (ops imx_sec_dsim_ops [sec_mipi_dsim_imx])
[ 2.772141] imx-drm display-subsystem: bound 32fd8000.hdmi (ops dw_hdmi_imx_ops)
[ 2.772468] [drm] Initialized imx-drm 1.0.0 20120507 for display-subsystem on minor 0
[ 2.869610] imx-drm display-subsystem: [drm] fb0: imx-drmdrmfb frame buffer device
[ 5.099098] systemd[1]: Starting Load Kernel Module drm...
[ 5.188031] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 5.188992] systemd[1]: Finished Load Kernel Module drm.
[ 5.262319] [drm] Initialized vivante 1.0.0 20170808 for 40000000.mix_gpu_ml on minor 1
torizon@verdin-imx8mp-15404184:~$ dmesg | grep dsim
[ 0.000000] Kernel command line: root=LABEL=otaroot rootfstype=ext4 quiet logo.nologo vt.global_cursor_defau lt=0 plymouth.ignore-serial-consoles splash fbcon=map:3 ostree=/ostree/boot.1/torizon/7b778d635701b4e0bbc49652c 421a587ae63ff3c6cbfc07d964084a23df7631d/0 dy
[ 2.759952] Kernel module loaded from ramdisk: sec_dsim - result: 0
[ 2.771246] imx_sec_dsim_drv 32e60000.mipi_dsi: sec-dsim bridge bind begin
[ 2.771290] imx_sec_dsim_drv 32e60000.mipi_dsi: version number is 0x1060200
[ 2.772085] imx_sec_dsim_drv 32e60000.mipi_dsi: sec-dsim bridge bind end
[ 2.916294] Kernel module loaded from ramdisk: sec_mipi_dsim_imx - result: 0
[ 3.259164] imx_sec_dsim_drv 32e60000.mipi_dsi: p: min = 1, max = 6, m: min = 88, max = 1023, s: min = 0, ma x = 5
[ 3.259252] imx_sec_dsim_drv 32e60000.mipi_dsi: fout = 390000, fin = 12000, m = 130, p = 1, s = 2, best_delt a = 0
[ 3.259262] imx_sec_dsim_drv 32e60000.mipi_dsi: no pre-exist hpar can be used
[ 18.521539] imx_sec_dsim_drv 32e60000.mipi_dsi: p: min = 1, max = 6, m: min = 88, max = 1023, s: min = 0, ma x = 5
[ 18.521629] imx_sec_dsim_drv 32e60000.mipi_dsi: fout = 390000, fin = 12000, m = 130, p = 1, s = 2, best_delt a = 0
[ 18.521640] imx_sec_dsim_drv 32e60000.mipi_dsi: no pre-exist hpar can be used
torizon@verdin-imx8mp-15404184:~$ dmesg | grep adv
[ 0.000000] Kernel command line: root=LABEL=otaroot rootfstype=ext4 quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash fbcon=map:3 ostree=/ostree/boot.1/torizon/7b778d635701b4e0bbc49652c421a587ae63ff3c6cbfc07d964084a23df7631d/0
[ 1.052362] adv7511 1-0039: Rev. 20
[ 4.325789] systemd[1]: System time before build time, advancing clock.
With this, we are also able to generate a test colorbar pattern by setting the registers directly on ADV7535 using i2cset, implying ADV7535 to HDMI Sink display is working correctly. The problem lies in how iMX8MP is communicating with ADV7535.
We are still not getting any output on the display.
We would like to understand, is there any difference in how NXP have implemented ADV7535 in its products and how we are implementing it in terms of software as well as hardware approach.
标记 (2)
1,170 次查看
joanxie
I have already shared the imx8mp dts file before, firstly, you need set this bridge in the dts correctly, then the adv7535 driver is
https://github.com/nxp-imx/linux-imx/blob/lf-6.12.y/drivers/gpu/drm/bridge/adv7511/adv7511_drv.c
988 次查看
sgour
Hi @joanxie,
Thank you for guiding to the NXP kernel source.
We have made our device tree in-line with the imx8mp-evk.dts of NXP kernel 5.15y(not 6.12 that you've shared), and our displays working for certain resolutions, but not the resolution we are targeting i.e 1024x768.
We haven't made any other change, other than the device tree for adv7535. On Toradex kernel 5.15.2.x.
Below is a table of what's working and what's not.
ResolutionAspect RatioStandardCommon Refresh RatesRealtek DisplayDell Monitor
640×4804:3Both60 HzWorkingWorking
800×6004:3VESA60–75 HzWorkingWorking
1024×7684:3VESA60–75 HzBlank/ Flicker on Disable
Internal timing generator
No output
1280×7685:3VESA60 HzNo outputNo output
1280×72016:9Both24/25/30/50/60 HzWorkingWorking
1366×76816:9VESA60 HzNo outputNo output
1920×1080p16:9Both24/25/30/50/60 HzWorkingWorking
What could be the possible reasons that only 1024x768 is not working? Other resolutions are working just by plugging HDMI as it should.
标记 (2)
937 次查看
joanxie
if you use 5.15, just change the branch to 5.15, since your source code is the third party company, I'm not sure how your driver is, but refer to the nxp adv7535 driver
linux-imx/drivers/gpu/drm/bridge/adv7511/adv7511_drv.c at lf-5.15.y · nxp-imx/linux-imx · GitHub
not all of resolution can be supported, the valid clock are as below, if you need new clock, you must add there and add new clock in the clock driver
static const int valid_clocks[] = {
148500,
135000,
132000,
108000,
78750,
74250,
65000,
49500,
40000,
31500,
%3CLINGO-SUB%20id%3D%22lingo-sub-2137314%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EADV7535%EF%BC%9A%E6%98%BE%E7%A4%BA%E5%B1%8F%E4%B8%8A%E6%97%A0%E5%9B%BE%E5%83%8F%E8%BE%93%E5%87%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137314%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%9B%A2%E9%98%9F%E3%80%81%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%88%91%E4%BB%AC%E6%AD%A3%E5%9C%A8%E5%9F%BA%E4%BA%8E%20Verdin%20Yavia%3CSTRONG%3E%20IMX8M%20Plus%20%E7%9A%84%E5%AE%9A%E5%88%B6%E8%BD%BD%E6%9D%BF%E4%B8%8A%E5%BC%80%E5%8F%91%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%3E%20DSI%20%E8%BD%AC%20HDMI%20%E5%8F%98%E6%B5%81%E5%99%A8%20(%3C%2FSPAN%3E%3CSTRONG%3E%20ADV7535)%E3%80%82%3C%2FSTRONG%3E%3CSTRONG%3E%20%E6%88%91%E4%BB%AC%E5%B7%B2%E7%BB%8F%E6%9B%BF%E6%8D%A2%E4%BA%86%20ADV7535%20%E8%80%8C%E4%B8%8D%E6%98%AF%20LT8912B%20MIPI%20DSI%20%E8%BD%AC%20HDMI%3C%2FSTRONG%3E%3CSPAN%3E%20%E6%A1%A5%E6%8E%A5%E5%99%A8%20%EF%BC%8C%E5%90%8E%E8%80%85%E8%87%AA%E5%B8%A6%20Toradex%20%E8%BD%BD%E6%9D%BF%E3%80%82%E6%88%91%E4%BB%AC%E4%BD%BF%E7%94%A8%3CSTRONG%3E%20I2C%20%E9%80%9A%E9%81%93%202%3C%2FSTRONG%3E%20%3CSTRONG%3E%E4%B8%8E%20ADV7535%20DSI%20%E8%BD%AC%20HDMI%20%E6%A1%A5%E6%8E%A5%E5%99%A8%E8%BF%9B%E8%A1%8C%3C%2FSTRONG%3E%20%E9%80%9A%E4%BF%A1%EF%BC%8C%E8%BF%99%E4%B8%8E%E4%BD%BF%E7%94%A8%E4%B8%8D%E5%90%8C%E7%9A%84%20I2C%20%E9%80%9A%E9%81%93%E7%9A%84%20Yavia%20%E8%BD%BD%E6%9D%BF%E4%B8%8D%E5%90%8C%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E4%BB%AC%E5%AF%B9%E8%AE%BE%E5%A4%87%E6%A0%91%E8%BF%9B%E8%A1%8C%E4%BA%86%E4%BB%A5%E4%B8%8B%E6%9B%B4%E6%96%B0%E4%BB%A5%E5%8F%8D%E6%98%A0%E8%BF%99%E4%B8%80%E5%8F%98%E5%8C%96%EF%BC%9A%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId-1972035252%22%20id%3D%22toc-hId-1999772785%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22rkathar_0-1753091144426.png%22%20style%3D%22width%3A%2018px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rkathar_0-1753091144426.png%22%20style%3D%22width%3A%2018px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348465i67091B09F572E7A6%2Fimage-dimensions%2F18x18%3Fv%3Dv2%22%20width%3D%2218%22%20height%3D%2218%22%20role%3D%22button%22%20title%3D%22rkathar_0-1753091144426.png%22%20alt%3D%22rkathar_0-1753091144426.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%E8%AE%BE%E5%A4%87%E6%A0%91%E5%8F%98%E6%9B%B4%3C%2FH3%3E%3CP%3E%3CSTRONG%3E1.%3CSPAN%3E%20%3C%2FSPAN%3Everdin-imx8mp_dsi-to-hdmi_overlay.dts%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E5%88%A0%E9%99%A4%E7%8E%B0%E6%9C%89%3CSPAN%3E%20%3C%2FSPAN%3Ehdmi_lontium_lt8912%3CSPAN%3E%20%3C%2FSPAN%3E%E8%8A%82%E7%82%B9%E3%80%82%3C%2FLI%3E%3CLI%3E%E5%9C%A8%20I2C2%20%E8%8A%82%E7%82%B9%E4%B8%8B%E6%96%B0%E5%A2%9E%3CSPAN%3E%20%3C%2FSPAN%3Ehdmi_adv7535%3CSPAN%3E%20%3C%2FSPAN%3E%E8%8A%82%E7%82%B9%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSTRONG%3E2.%3CSPAN%3E%20%3C%2FSPAN%3Eimx8mp-verdin.dtsi%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E5%88%A0%E9%99%A4%E4%BA%86%3CSPAN%3E%20%3C%2FSPAN%3Ehdmi_lontium_lt8912%3CSPAN%3E%20%3C%2FSPAN%3E%E8%8A%82%E7%82%B9%E3%80%82%3C%2FLI%3E%3CLI%3E%E4%BB%8E%3CSPAN%3E%20%3C%2FSPAN%3Ehdmi_connector%3CSPAN%3E%20%3C%2FSPAN%3E%E8%8A%82%E7%82%B9%E4%B8%AD%E5%88%A0%E9%99%A4%E4%BA%86%20Lontium%20%E5%BC%95%E8%84%9A%E8%BF%9E%E6%8E%A5%E7%BB%86%E8%8A%82%E3%80%82%3C%2FLI%3E%3CLI%3E%E5%B7%B2%E6%B7%BB%E5%8A%A0%3CSPAN%3E%20%3C%2FSPAN%3Ehdmi_adv7535%3CSPAN%3E%20%3C%2FSPAN%3E%E4%BD%9C%E4%B8%BA%20I2C2%20%E4%B8%8B%E7%9A%84%E5%AD%90%E8%8A%82%E7%82%B9%E3%80%82%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22rkathar_7-1753091605150.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rkathar_7-1753091605150.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348477i75B4DC244B2AE7A0%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22rkathar_7-1753091605150.png%22%20alt%3D%22rkathar_7-1753091605150.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22rkathar_8-1753091613771.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rkathar_8-1753091613771.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348478i8710FCCEA202BC8E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22rkathar_8-1753091613771.png%22%20alt%3D%22rkathar_8-1753091613771.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22rkathar_9-1753091622755.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rkathar_9-1753091622755.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348480i106D9CE8586E0E0F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22rkathar_9-1753091622755.png%22%20alt%3D%22rkathar_9-1753091622755.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FLI%3E%3C%2FUL%3E%3CH3%20id%3D%22toc-hId-164580789%22%20id%3D%22toc-hId-192318322%22%3E%26nbsp%3B%3C%2FH3%3E%3CH3%20id%3D%22toc-hId--1642873674%22%20id%3D%22toc-hId--1615136141%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22rkathar_1-1753091144431.png%22%20style%3D%22width%3A%2021px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rkathar_1-1753091144431.png%22%20style%3D%22width%3A%2021px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348464i540048E5F3074856%2Fimage-dimensions%2F21x21%3Fv%3Dv2%22%20width%3D%2221%22%20height%3D%2221%22%20role%3D%22button%22%20title%3D%22rkathar_1-1753091144431.png%22%20alt%3D%22rkathar_1-1753091144431.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%E6%9B%B4%E6%94%B9%E5%90%8E%E7%9A%84%E8%A7%82%E5%AF%9F%E7%BB%93%E6%9E%9C%3C%2FH3%3E%3COL%3E%3CLI%3E%3CP%3E%E6%88%90%E5%8A%9F%E8%AF%BB%E5%86%99%20ADV7535%20%E7%9A%84%E5%86%85%E9%83%A8%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82%3C%2FP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22rkathar_2-1753091254723.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rkathar_2-1753091254723.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348468iBF33A34B9BE03572%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22rkathar_2-1753091254723.png%22%20alt%3D%22rkathar_2-1753091254723.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3COL%3E%3CLI%3E%3CP%3E%E8%83%BD%E5%A4%9F%E8%BD%AC%E5%82%A8%20I2C%20%E6%95%B0%E6%8D%AE%EF%BC%9A%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20translate%3D%22no%22%3Etorizon%40verdin-imx8mp-15404184%3A~%24%20i2cdump%20-y%20-f%201%200x39%0ANo%20size%20specified%20(using%20byte-data%20access)%0A%20%20%20%20%200%20%201%20%202%20%203%20%204%20%205%20%206%20%207%20%208%20%209%20%20a%20%20b%20%20c%20%20d%20%20e%20%20f%20%20%20%200123456789abcdef%0A00%3A%2014%2000%2000%2000%2000%2000%2000%2000%2000%2000%2041%200e%20bc%2018%2001%2013%20%20%20%20%3F.........A%3F%3F%3F%3F%3F%0A10%3A%2025%2037%2000%2000%2000%2000%2038%2000%2046%2062%2004%20a8%2000%2000%201c%2084%20%20%20%20%257....8.Fb%3F%3F..%3F%3F%0A20%3A%201c%20bf%2004%20a8%201e%2070%2002%201e%2000%2000%2004%20a8%2008%2012%201b%20ac%20%20%20%20%3F%3F%3F%3F%3Fp%3F%3F..%3F%3F%3F%3F%3F%3F%0A30%3A%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2080%2000%2000%2000%20b0%20%20%20%20...........%3F...%3F%0A40%3A%2000%2050%20f0%2076%2010%2068%2068%2068%2068%2000%2080%2000%2000%2000%2000%2000%20%20%20%20.P%3Fv%3Fhhhh.%3F.....%0A50%3A%2000%2000%2002%200d%206d%2002%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%20%20%20%20..%3F%3Fm%3F..........%0A60%3A%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%20%20%20%20................%0A70%3A%2001%200a%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%20%20%20%20%3F%3F..............%0A80%3A%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%20%20%20%20................%0A90%3A%2000%2000%2000%2000%20c0%2000%2040%2000%2003%2002%20e0%2018%2030%2061%2000%2000%20%20%20%20....%3F.%40.%3F%3F%3F%3F0a..%0Aa0%3A%2000%2000%20a4%20a4%2008%2004%2000%2000%2000%2000%2000%2040%2000%2000%2040%2014%20%20%20%20..%3F%3F%3F%3F.....%40..%40%3F%0Ab0%3A%2000%2000%2000%2000%2000%2000%2000%2000%2000%2000%2010%2000%2000%2000%2000%2000%20%20%20%20..........%3F.....%0Ac0%3A%2000%2000%2000%2000%2000%2000%2006%2000%2000%2003%2000%2000%2002%2000%2001%2004%20%20%20%20......%3F..%3F..%3F.%3F%3F%0Ad0%3A%200c%20ff%2080%2080%2080%2000%2000%2000%2000%2000%2000%2000%2000%2000%2088%2001%20%20%20%20%3F.%3F%3F%3F.........%3F%3F%0Ae0%3A%20d0%2070%2001%2000%2000%2000%20fd%2000%2000%2000%2052%2046%2000%2000%2000%2000%20%20%20%20%3Fp%3F...%3F...RF....%0Af0%3A%2095%2004%20ff%2000%2000%2000%2000%2000%2000%2000%207d%20aa%201c%2000%20b0%2000%20%20%20%20%3F%3F........%7D%3F%3F.%3F.%3C%2FPRE%3E%3COL%3E%3CLI%3E%E6%A3%80%E6%B5%8B%20HDMI%20%E6%98%BE%E7%A4%BA%E5%99%A8%EF%BC%8C%E5%B9%B6%E5%9C%A8%20i.MX8MP%20%E4%B8%8A%E6%A3%80%E7%B4%A2%20EDID%20%E6%95%B0%E6%8D%AE%E3%80%82HDMI-A%20-1%20%E6%98%AF%20DSI%20%E8%BD%AC%20HDMI%20%E7%AB%AF%E5%8F%A3%EF%BC%8CHDMI-A-2%20%E6%98%AF%E5%8E%9F%E7%94%9F%20HDMI%20%E7%AB%AF%E5%8F%A3%E3%80%82%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22rkathar_3-1753091284687.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rkathar_3-1753091284687.jpeg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348469i784BF0DAE56F4A4D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22rkathar_3-1753091284687.jpeg%22%20alt%3D%22rkathar_3-1753091284687.jpeg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CBR%20%2F%3E%3CPRE%20translate%3D%22no%22%3Eroot%3CSPAN%20class%3D%22%22%3E%40%3C%2FSPAN%3Everdin%3CSPAN%20class%3D%22%22%3E-%3C%2FSPAN%3Eimx8mp%3CSPAN%20class%3D%22%22%3E-%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E15288064%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3A%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%2F%3C%2FSPAN%3Ehome%3CSPAN%20class%3D%22%22%3E%2F%3C%2FSPAN%3Etorizon%3CSPAN%20class%3D%22%22%3E%23%20cat%20%2Fsys%2Fclass%2Fdrm%2Fcard0-HDMI-A-1%2Fedid%20%7C%20edid-decode%3C%2FSPAN%3E%0Aedid%3CSPAN%20class%3D%22%22%3E-%3C%2FSPAN%3Edecode%20%3CSPAN%20class%3D%22%22%3E(%3C%2FSPAN%3Ehex%3CSPAN%20class%3D%22%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3A%3C%2FSPAN%3E%0A%20%0A%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20ff%20ff%20ff%20ff%20ff%20ff%20%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E30%3C%2FSPAN%3E%20ae%20%3CSPAN%20class%3D%22%22%3E86%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E10%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E01%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E01%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E01%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E01%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22%22%3E22%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E15%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E01%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E03%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E80%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E29%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E1%3C%2FSPAN%3Ea%20%3CSPAN%20class%3D%22%22%3E78%3C%2FSPAN%3E%20ee%20e5%20b5%20a3%20%3CSPAN%20class%3D%22%22%3E55%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E49%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E99%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E27%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22%22%3E13%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E50%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E54%3C%2FSPAN%3E%20af%20ef%20%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E61%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E40%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E81%3C%2FSPAN%3E%20c0%20%3CSPAN%20class%3D%22%22%3E81%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E80%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E81%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E8%3C%2FSPAN%3Ea%20%3CSPAN%20class%3D%22%22%3E81%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E90%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22%22%3E95%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E95%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E0%3C%2FSPAN%3Ef%20%3CSPAN%20class%3D%22%22%3E01%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E01%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E64%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E19%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E40%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E41%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E26%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E30%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E18%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E88%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22%22%3E36%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20a0%20%3CSPAN%20class%3D%22%22%3E1%3C%2FSPAN%3Ed%20%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E18%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20fc%20%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E4%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ec%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E45%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E4%3C%2FSPAN%3Ee%0A%3CSPAN%20class%3D%22%22%3E20%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E4%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ec%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E31%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E39%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E35%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E30%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E77%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E44%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E0%3C%2FSPAN%3Ea%20%3CSPAN%20class%3D%22%22%3E20%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20fd%20%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E32%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22%22%3E4%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ec%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E1%3C%2FSPAN%3Ee%20%3CSPAN%20class%3D%22%22%3E51%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E0%3C%2FSPAN%3Ee%20%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E0%3C%2FSPAN%3Ea%20%3CSPAN%20class%3D%22%22%3E20%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E20%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E20%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E20%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E20%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E20%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20ff%0A%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E42%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E33%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E34%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E33%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E32%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E38%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E34%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E35%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E0%3C%2FSPAN%3Ea%20%3CSPAN%20class%3D%22%22%3E20%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E20%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E20%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E20%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E01%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E0%3C%2FSPAN%3Eb%0A%20%0A%3CSPAN%20class%3D%22%22%3E02%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E03%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E21%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E71%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E4%3C%2FSPAN%3Ee%20%3CSPAN%20class%3D%22%22%3E06%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E07%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E02%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E03%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E15%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E96%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E11%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E12%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E13%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E04%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E14%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22%22%3E05%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E1%3C%2FSPAN%3Ef%20%3CSPAN%20class%3D%22%22%3E90%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E23%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E09%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E07%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E07%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E83%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E01%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E65%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E03%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E0%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ec%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E10%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E8%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ec%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E0%3C%2FSPAN%3Ea%20d0%20%3CSPAN%20class%3D%22%22%3E90%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E20%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E40%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E31%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E20%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E0%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ec%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E40%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E55%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20b9%20%3CSPAN%20class%3D%22%22%3E88%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E21%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E18%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E01%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E1%3C%2FSPAN%3Ed%20%3CSPAN%20class%3D%22%22%3E80%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E18%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E71%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E1%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ec%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E16%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E20%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E58%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E2%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ec%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E25%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20b9%0A%3CSPAN%20class%3D%22%22%3E88%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E21%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E9%3C%2FSPAN%3Ee%20%3CSPAN%20class%3D%22%22%3E01%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E1%3C%2FSPAN%3Ed%20%3CSPAN%20class%3D%22%22%3E80%3C%2FSPAN%3E%20d0%20%3CSPAN%20class%3D%22%22%3E72%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E1%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ec%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E16%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E20%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E10%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E2%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ec%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E25%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22%22%3E80%3C%2FSPAN%3E%20b9%20%3CSPAN%20class%3D%22%22%3E88%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E21%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E9%3C%2FSPAN%3Ee%20%3CSPAN%20class%3D%22%22%3E01%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E1%3C%2FSPAN%3Ed%20%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20bc%20%3CSPAN%20class%3D%22%22%3E52%3C%2FSPAN%3E%20d0%20%3CSPAN%20class%3D%22%22%3E1%3C%2FSPAN%3Ee%20%3CSPAN%20class%3D%22%22%3E20%3C%2FSPAN%3E%20b8%0A%3CSPAN%20class%3D%22%22%3E28%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E55%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E40%3C%2FSPAN%3E%20b9%20%3CSPAN%20class%3D%22%22%3E88%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E21%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E1%3C%2FSPAN%3Ee%20%3CSPAN%20class%3D%22%22%3E02%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E3%3C%2FSPAN%3Ea%20%3CSPAN%20class%3D%22%22%3E80%3C%2FSPAN%3E%20d0%20%3CSPAN%20class%3D%22%22%3E72%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E38%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E2%3C%2FSPAN%3Ed%0A%3CSPAN%20class%3D%22%22%3E40%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E10%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E2%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ec%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E45%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E80%3C%2FSPAN%3E%20b9%20%3CSPAN%20class%3D%22%22%3E88%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E21%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E1%3C%2FSPAN%3Ee%20%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E00%3C%2FSPAN%3E%20d0%3C%2FPRE%3E%3CH3%20id%3D%22toc-hId-844639159%22%20id%3D%22toc-hId-872376692%22%3E%26nbsp%3B%3C%2FH3%3E%3CH3%20id%3D%22toc-hId--962815304%22%20id%3D%22toc-hId--935077771%22%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22rkathar_4-1753091284695.png%22%20style%3D%22width%3A%2018px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rkathar_4-1753091284695.png%22%20style%3D%22width%3A%2018px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348470i93AFBB4601C362C0%2Fimage-dimensions%2F18x18%3Fv%3Dv2%22%20width%3D%2218%22%20height%3D%2218%22%20role%3D%22button%22%20title%3D%22rkathar_4-1753091284695.png%22%20alt%3D%22rkathar_4-1753091284695.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%20%3C%2FSPAN%3E%E9%81%87%E5%88%B0%E7%9A%84%E9%97%AE%E9%A2%98%3C%2FH3%3E%3COL%3E%3CLI%3E%E8%BF%9E%E6%8E%A5%E7%9A%84%20HDMI%20%E6%98%BE%E7%A4%BA%E5%99%A8%E4%B8%8A%3CSTRONG%3E%E6%B2%A1%E6%9C%89%E5%9B%BE%E5%83%8F%E8%BE%93%E5%87%BA%3C%2FSTRONG%3E%3CSPAN%3E%20%3C%2FSPAN%3E%E3%80%82%3C%2FLI%3E%3CLI%3E%3CSTRONG%3Edmesg%20%E6%97%A5%E5%BF%97%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FSTRONG%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CPRE%20translate%3D%22no%22%3Eimx_sec_dsim_drv%20%3CSPAN%20class%3D%22%22%3E32e60000%3C%2FSPAN%3E.mipi_dsi%3A%20failed%20to%20%3CSPAN%20class%3D%22%22%3Eget%3C%2FSPAN%3E%20pmsk%20%3CSPAN%20class%3D%22%22%3Efor%3C%2FSPAN%3E%3A%20fin%20%3D%20%3CSPAN%20class%3D%22%22%3E12000%3C%2FSPAN%3E%2C%20fout%20%3D%20%3CSPAN%20class%3D%22%22%3E0%3C%2FSPAN%3E%0A%3C%2FPRE%3E%3C%2FLI%3E%3C%2FOL%3E%3CH3%20id%3D%22toc-hId-1524697529%22%20id%3D%22toc-hId-1552435062%22%3E%26nbsp%3B%3C%2FH3%3E%3CBR%20%2F%3E%3CH3%20id%3D%22toc-hId--282756934%22%20id%3D%22toc-hId--255019401%22%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22rkathar_5-1753091284691.png%22%20style%3D%22width%3A%2022px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rkathar_5-1753091284691.png%22%20style%3D%22width%3A%2022px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348471iA3A00F98FF266BD6%2Fimage-dimensions%2F22x22%3Fv%3Dv2%22%20width%3D%2222%22%20height%3D%2222%22%20role%3D%22button%22%20title%3D%22rkathar_5-1753091284691.png%22%20alt%3D%22rkathar_5-1753091284691.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%20%3C%2FSPAN%3E%E6%95%85%E9%9A%9C%E6%8E%92%E9%99%A4%E5%B0%9D%E8%AF%95%3C%2FH3%3E%3CP%3E%E6%88%91%E4%BB%AC%E5%B0%9D%E8%AF%95%E4%BF%AE%E6%94%B9%E8%AE%BE%E5%A4%87%E6%A0%91%E4%B8%AD%E7%9A%84%20MIPI%20DSI%20%E6%8E%A7%E5%88%B6%E5%99%A8%E6%97%B6%E9%92%9F%E8%AE%BE%E7%BD%AE%EF%BC%8C%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%EF%BC%9A%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3Emipi_dsi%3A%20mipi_dsi%40%3CSPAN%20class%3D%22%22%3E32e60000%3C%2FSPAN%3E%20%7B%0A%09%09%09%09%3CSPAN%20class%3D%22%22%3E%23address-cells%20%3D%20%3CSPAN%20class%3D%22%22%3E%26lt%3B1%26gt%3B%3C%2FSPAN%3E%3B%3C%2FSPAN%3E%0A%09%09%09%09%3CSPAN%20class%3D%22%22%3E%23size-cells%20%3D%20%3CSPAN%20class%3D%22%22%3E%26lt%3B0%26gt%3B%3C%2FSPAN%3E%3B%3C%2FSPAN%3E%0A%09%09%09%09compatible%20%3D%20%3CSPAN%20class%3D%22%22%3E%22fsl%2Cimx8mp-mipi-dsim%22%3C%2FSPAN%3E%3B%0A%09%09%09%09reg%20%3D%20%26lt%3B%3CSPAN%20class%3D%22%22%3E0x32e60000%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E0x10000%3C%2FSPAN%3E%26gt%3B%3B%0A%09%09%09%09clocks%20%3D%20%26lt%3B%26amp%3Bmedia_blk_ctrl%20IMX8MP_CLK_MEDIA_BLK_CTRL_MIPI_DSI_PCLK%26gt%3B%2C%0A%09%09%09%09%09%20%26lt%3B%26amp%3Bmedia_blk_ctrl%20IMX8MP_CLK_MEDIA_BLK_CTRL_MIPI_DSI_CLKREF%26gt%3B%3B%0A%09%09%09%09clock-names%20%3D%20%3CSPAN%20class%3D%22%22%3E%22cfg%22%3C%2FSPAN%3E%2C%20%3CSPAN%20class%3D%22%22%3E%22pll-ref%22%3C%2FSPAN%3E%3B%0A%09%09%09%09assigned-clocks%20%3D%20%26lt%3B%26amp%3Bclk%20IMX8MP_CLK_MEDIA_MIPI_PHY1_REF%26gt%3B%3B%0A%09%09%09%09assigned-clock-parents%20%3D%20%26lt%3B%26amp%3Bclk%20IMX8MP_CLK_24M%26gt%3B%3B%0A%09%09%09%09assigned-clock-rates%20%3D%20%26lt%3B%3CSPAN%20class%3D%22%22%3E11000000%3C%2FSPAN%3E%26gt%3B%3B%0A%09%09%09%09interrupts%20%3D%20%3CGIC_SPI%3E%3CSPAN%20class%3D%22%22%3E18%3C%2FSPAN%3E%20IRQ_TYPE_LEVEL_HIGH%26gt%3B%3B%0A%09%09%09%09power-domains%20%3D%20%26lt%3B%26amp%3Bmipi_phy1_pd%26gt%3B%3B%0A%09%09%09%09status%20%3D%20%3CSPAN%20class%3D%22%22%3E%22disabled%22%3C%2FSPAN%3E%3B%0A%0A%09%09%09%09port%40%3CSPAN%20class%3D%22%22%3E0%3C%2FSPAN%3E%20%7B%0A%09%09%09%09%09dsim_from_lcdif%3A%20endpoint%20%7B%0A%09%09%09%09%09%09remote-endpoint%20%3D%20%26lt%3B%26amp%3Blcdif_to_dsim%26gt%3B%3B%0A%09%09%09%09%09%7D%3B%0A%09%09%09%09%7D%3B%0A%09%09%09%7D%3B%3C%2FGIC_SPI%3E%3C%2FPRE%3E%3CP%3E%E4%B8%8D%E8%BF%87%EF%BC%8C%E5%9C%A8%3CSPAN%3E%20%3C%2FSPAN%3Edmesg%20%E6%97%A5%E5%BF%97%E4%B8%AD%EF%BC%8C%E9%BB%98%E8%AE%A4%E9%A2%91%E7%8E%87%E4%BB%8D%E6%98%BE%E7%A4%BA%E4%B8%BA%20%3CSTRONG%3E12%20MHz%3C%2FSTRONG%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%E3%80%82%3C%2FP%3E%3CHR%20%2F%3E%3CH3%20id%3D%22toc-hId--2090211397%22%20id%3D%22toc-hId--2062473864%22%3E%26nbsp%3B%3C%2FH3%3E%3CH3%20id%3D%22toc-hId-397301436%22%20id%3D%22toc-hId-425038969%22%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22rkathar_6-1753091284693.png%22%20style%3D%22width%3A%2017px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rkathar_6-1753091284693.png%22%20style%3D%22width%3A%2017px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348472i7B92092D7931C307%2Fimage-dimensions%2F17x17%3Fv%3Dv2%22%20width%3D%2217%22%20height%3D%2217%22%20role%3D%22button%22%20title%3D%22rkathar_6-1753091284693.png%22%20alt%3D%22rkathar_6-1753091284693.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%20%3C%2FSPAN%3E%E8%A6%81%E6%B1%82%E6%BE%84%E6%B8%85%3C%2FH3%3E%3CP%3E%E6%88%91%E4%BB%AC%E5%B8%8C%E6%9C%9B%E6%82%A8%E8%83%BD%E5%B0%B1%E4%BB%A5%E4%B8%8B%E5%87%A0%E7%82%B9%E6%8F%90%E4%BE%9B%E6%8C%87%E5%AF%BC%EF%BC%9A%3C%2FP%3E%3COL%3E%3CLI%3E%E5%A6%82%E4%BD%95%E6%AD%A3%E7%A1%AE%E6%9B%B4%E6%96%B0%3CSPAN%3E%20%3C%2FSPAN%3E%3CSTRONG%3Efin%3CSPAN%3E%20%3C%2FSPAN%3E%E5%92%8C%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FSTRONG%3Efout%3CSPAN%3E%20%3C%2FSPAN%3E%E7%9A%84%E5%80%BC%EF%BC%8C%E4%BB%A5%E8%A7%A3%E5%86%B3%3CSPAN%3E%20%3C%2FSPAN%3Epmsk%3CSPAN%3E%20%3C%2FSPAN%3E%E9%94%99%E8%AF%AF%EF%BC%9F%3C%2FLI%3E%3CLI%3E%E8%A6%81%E9%80%9A%E8%BF%87%20ADV7535%20%E5%AE%9E%E7%8E%B0%E6%AD%A3%E7%A1%AE%E7%9A%84%E5%9B%BE%E5%83%8F%E8%BE%93%E5%87%BA%EF%BC%8C%E6%98%AF%E5%90%A6%3CSPAN%3E%3C%2FSPAN%3E%E9%9C%80%E8%A6%81%E5%AF%B9%3CSTRONG%3E%E8%AE%BE%E5%A4%87%E6%A0%91%E8%BF%9B%E8%A1%8C%E4%BB%BB%E4%BD%95%3C%2FSTRONG%3E%3CSPAN%3E%3C%2FSPAN%3E%E5%85%B6%E4%BB%96%E6%9B%B4%E6%94%B9%EF%BC%9F%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%E6%9C%9F%E5%BE%85%E6%82%A8%E7%9A%84%E8%A7%81%E8%A7%A3%E5%92%8C%E5%BB%BA%E8%AE%AE%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%AF%B7%E5%8F%82%E9%98%85%E9%9A%8F%E9%99%84%E7%9A%84%20dmesg%20%E6%97%A5%E5%BF%97%EF%BC%8C%E8%AF%A5%E8%AF%9D%E9%A2%98%E4%B8%AD%E7%9A%84%E8%AE%BE%E5%A4%87%E6%A0%91%E5%8F%A0%E5%8A%A0%E5%B1%82%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%B0%A2%E8%B0%A2%26amp%3B%20%EF%BC%8C%3CBR%20%2F%3ERupesh%20Kathar%3C%2FP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2FIMX8MPLUS%2Fpd-p%2FIMX8MPLUS%22%20class%3D%22lia-product-mention%22%20data-product%3D%2221-1%22%20target%3D%22_blank%22%3Eimx8mplus%3C%2FA%3E%23adv7535%20%23dsi%20%23hdmi%20%23mipi%20%23i2c%20%23i2s%20%3C%2FLI%3E%3C%2FOL%3E%3C%2FLI%3E%3C%2FOL%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2137314%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20Mini%20%7C%20i.MX%208M%20Nano%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2158855%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20ADV7535%3A%20No%20image%20output%20on%20display%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2158855%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%205.15%EF%BC%8C%E5%8F%AA%E9%9C%80%E5%B0%86%E5%88%86%E6%94%AF%E6%9B%B4%E6%94%B9%E4%B8%BA%205.15%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%82%A8%E7%9A%84%E6%BA%90%E4%BB%A3%E7%A0%81%E6%98%AF%E7%AC%AC%E4%B8%89%E6%96%B9%E5%85%AC%E5%8F%B8%E7%9A%84%EF%BC%8C%E6%88%91%E4%B8%8D%E6%B8%85%E6%A5%9A%E6%82%A8%E7%9A%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%A6%82%E4%BD%95%EF%BC%8C%E4%BD%86%E8%AF%B7%E5%8F%82%E8%80%83%20nxp%20adv7535%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2Flf-5.15.y%2Fdrivers%2Fgpu%2Fdrm%2Fbridge%2Fadv7511%2Fadv7511_drv.c%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Elinux-imx%2Fdrivers%2Fgpu%2Fdrm%2Fbridge%2Fadv7511%2Fadv7511_drv.c%20at%20lf-5.15.y%20-%20nxp-imx%2Flinux-imx%20-%20GitHub%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E5%B9%B6%E4%B8%8D%E6%98%AF%E6%89%80%E6%9C%89%E7%9A%84%E5%88%86%E8%BE%A8%E7%8E%87%E9%83%BD%E8%83%BD%E6%94%AF%E6%8C%81%EF%BC%8C%E6%9C%89%E6%95%88%E6%97%B6%E9%92%9F%E5%A6%82%E4%B8%8B%EF%BC%8C%E5%A6%82%E6%9E%9C%E9%9C%80%E8%A6%81%E6%96%B0%E6%97%B6%E9%92%9F%EF%BC%8C%E5%BF%85%E9%A1%BB%E5%9C%A8%E6%97%B6%E9%92%9F%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%B8%AD%E6%B7%BB%E5%8A%A0%E6%96%B0%E6%97%B6%E9%92%9F%E3%80%82%3C%2FP%3E%0A%3CDIV%3E%E9%9D%99%E6%80%81%E5%B8%B8%E9%87%8F%20int%20valid_clocks%5B%5D%20%3D%20%7B%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%20148500%2C%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%20135000%2C%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%20132000%2C%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%20108000%2C%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%2078750%2C%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%2074250%2C%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%2065000%2C%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%2049500%2C%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%2040000%2C%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%3E%2031500%2C%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%7D%3B%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2158015%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20ADV7535%3A%20No%20image%20output%20on%20display%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2158015%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F39586%22%20target%3D%22_blank%22%3E%40joanxie%3C%2FA%3E%2C%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E5%AF%B9%E6%81%A9%E6%99%BA%E6%B5%A6%E5%86%85%E6%A0%B8%E6%BA%90%E4%BB%A3%E7%A0%81%E7%9A%84%E6%8C%87%E5%AF%BC%E3%80%82%3CBR%20%2F%3E%E6%88%91%E4%BB%AC%E5%B7%B2%E7%BB%8F%E4%BD%BF%E6%88%91%E4%BB%AC%E7%9A%84%E8%AE%BE%E5%A4%87%E6%A0%91%E4%B8%8E%E6%81%A9%E6%99%BA%E6%B5%A6%E5%86%85%E6%A0%B85.15y%EF%BC%88%E4%B8%8D%E6%98%AF%E4%BD%A0%E5%85%B1%E4%BA%AB%E7%9A%846.12%EF%BC%89%E7%9A%84imx8mp-evk.dts%E4%BF%9D%E6%8C%81%E4%B8%80%E8%87%B4%EF%BC%8C%E6%88%91%E4%BB%AC%E7%9A%84%E6%98%BE%E7%A4%BA%E5%99%A8%E9%80%82%E7%94%A8%E4%BA%8E%E6%9F%90%E4%BA%9B%E5%88%86%E8%BE%A8%E7%8E%87%EF%BC%8C%E4%BD%86%E4%B8%8D%E9%80%82%E7%94%A8%E4%BA%8E%E6%88%91%E4%BB%AC%E7%9A%84%E7%9B%AE%E6%A0%87%E5%88%86%E8%BE%A8%E7%8E%87%EF%BC%8C%E5%8D%B31024x768%E3%80%82%3CBR%20%2F%3E%E9%99%A4%E4%BA%86%20adv7535%20%E7%9A%84%E8%AE%BE%E5%A4%87%E6%A0%91%E5%A4%96%EF%BC%8C%E6%88%91%E4%BB%AC%E6%B2%A1%E6%9C%89%E5%81%9A%E4%BB%BB%E4%BD%95%E5%85%B6%E4%BB%96%E6%9B%B4%E6%94%B9%E3%80%82%E4%BD%BF%E7%94%A8%20Toradex%20%E5%86%85%E6%A0%B8%205.15.2.x%E3%80%82%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%B8%8B%E9%9D%A2%E7%9A%84%E8%A1%A8%E6%A0%BC%E5%88%97%E5%87%BA%E4%BA%86%E5%93%AA%E4%BA%9B%E6%96%B9%E6%B3%95%E6%9C%89%E6%95%88%EF%BC%8C%E5%93%AA%E4%BA%9B%E6%96%B9%E6%B3%95%E6%97%A0%E6%95%88%E3%80%82%3C%2FP%3E%3CTABLE%20width%3D%22591%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20width%3D%2276%22%20height%3D%2219%22%20class%3D%22%22%3E%E5%88%86%E8%BE%A8%E7%8E%87%3C%2FTD%3E%3CTD%20width%3D%2279%22%20class%3D%22%22%3E%E5%AE%BD%E9%AB%98%E6%AF%94%3C%2FTD%3E%3CTD%20width%3D%2259%22%20class%3D%22%22%3E%E6%A0%87%E5%87%86%3C%2FTD%3E%3CTD%20width%3D%22144%22%20class%3D%22%22%3E%E5%B8%B8%E8%A7%81%E5%88%B7%E6%96%B0%E7%8E%87%3C%2FTD%3E%3CTD%20width%3D%22153%22%20class%3D%22%22%3ERealtek%20%E6%98%BE%E7%A4%BA%E5%99%A8%3C%2FTD%3E%3CTD%20width%3D%2280%22%20class%3D%22%22%3E%E6%88%B4%E5%B0%94%E6%98%BE%E7%A4%BA%E5%99%A8%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20height%3D%2219%22%20class%3D%22%22%3E640%C3%97480%3C%2FTD%3E%3CTD%20class%3D%22%22%3E4%3A3%3C%2FTD%3E%3CTD%20class%3D%22%22%3E%E5%8F%8C%E5%90%91%3C%2FTD%3E%3CTD%20class%3D%22%22%3E60%20%E8%B5%AB%E5%85%B9%3C%2FTD%3E%3CTD%20class%3D%22%22%3E%E5%B7%A5%E4%BD%9C%3C%2FTD%3E%3CTD%20class%3D%22%22%3E%E5%B7%A5%E4%BD%9C%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20height%3D%2219%22%20class%3D%22%22%3E800%C3%97600%3C%2FTD%3E%3CTD%20class%3D%22%22%3E4%3A3%3C%2FTD%3E%3CTD%20class%3D%22%22%3EVESA%3C%2FTD%3E%3CTD%20class%3D%22%22%3E60-75%20%E8%B5%AB%E5%85%B9%3C%2FTD%3E%3CTD%20class%3D%22%22%3E%E5%B7%A5%E4%BD%9C%3C%2FTD%3E%3CTD%20class%3D%22%22%3E%E5%B7%A5%E4%BD%9C%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20height%3D%2238%22%20class%3D%22%22%3E1024%C3%97768%3C%2FTD%3E%3CTD%20class%3D%22%22%3E4%3A3%3C%2FTD%3E%3CTD%20class%3D%22%22%3EVESA%3C%2FTD%3E%3CTD%20class%3D%22%22%3E60-75%20%E8%B5%AB%E5%85%B9%3C%2FTD%3E%3CTD%20width%3D%22153%22%20class%3D%22%22%3E%E7%A9%BA%E7%99%BD%2F%E9%97%AA%E7%83%81%E6%97%B6%20%E7%A6%81%E7%94%A8%3CBR%20%2F%3E%E5%86%85%E9%83%A8%E5%AE%9A%E6%97%B6%E5%8F%91%E7%94%9F%E5%99%A8%3C%2FTD%3E%3CTD%20class%3D%22%22%3E%E6%97%A0%E8%BE%93%E5%87%BA%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20height%3D%2219%22%20class%3D%22%22%3E1280%C3%97768%3C%2FTD%3E%3CTD%20class%3D%22%22%3E5%3A3%3C%2FTD%3E%3CTD%20class%3D%22%22%3EVESA%3C%2FTD%3E%3CTD%20class%3D%22%22%3E60%20%E8%B5%AB%E5%85%B9%3C%2FTD%3E%3CTD%20class%3D%22%22%3E%E6%97%A0%E8%BE%93%E5%87%BA%3C%2FTD%3E%3CTD%20class%3D%22%22%3E%E6%97%A0%E8%BE%93%E5%87%BA%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20height%3D%2219%22%20class%3D%22%22%3E1280%C3%97720%3C%2FTD%3E%3CTD%20class%3D%22%22%3E16%3A9%3C%2FTD%3E%3CTD%20class%3D%22%22%3E%E5%8F%8C%E5%90%91%3C%2FTD%3E%3CTD%20class%3D%22%22%3E24%2F25%2F30%2F50%2F60%20%E8%B5%AB%E5%85%B9%3C%2FTD%3E%3CTD%20class%3D%22%22%3E%E5%B7%A5%E4%BD%9C%3C%2FTD%3E%3CTD%20class%3D%22%22%3E%E5%B7%A5%E4%BD%9C%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20height%3D%2219%22%20class%3D%22%22%3E1366%C3%97768%3C%2FTD%3E%3CTD%20class%3D%22%22%3E16%3A9%3C%2FTD%3E%3CTD%20class%3D%22%22%3EVESA%3C%2FTD%3E%3CTD%20class%3D%22%22%3E60%20%E8%B5%AB%E5%85%B9%3C%2FTD%3E%3CTD%20class%3D%22%22%3E%E6%97%A0%E8%BE%93%E5%87%BA%3C%2FTD%3E%3CTD%20class%3D%22%22%3E%E6%97%A0%E8%BE%93%E5%87%BA%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20height%3D%2219%22%20class%3D%22%22%3E1920%C3%971080p%3C%2FTD%3E%3CTD%20class%3D%22%22%3E16%3A9%3C%2FTD%3E%3CTD%20class%3D%22%22%3E%E5%8F%8C%E5%90%91%3C%2FTD%3E%3CTD%20class%3D%22%22%3E24%2F25%2F30%2F50%2F60%20%E8%B5%AB%E5%85%B9%3C%2FTD%3E%3CTD%20class%3D%22%22%3E%E5%B7%A5%E4%BD%9C%3C%2FTD%3E%3CTD%20class%3D%22%22%3E%E5%B7%A5%E4%BD%9C%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3CBR%20%2F%3E%E5%8F%AA%E6%9C%89%201024x768%20%E4%B8%8D%E5%B7%A5%E4%BD%9C%E7%9A%84%E5%8F%AF%E8%83%BD%E5%8E%9F%E5%9B%A0%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%E5%85%B6%E4%BB%96%E5%88%86%E8%BE%A8%E7%8E%87%E5%8F%AA%E9%9C%80%E6%8F%92%E5%85%A5%20HDMI%20%E5%8D%B3%E5%8F%AF%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2145624%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20ADV7535%3A%20No%20image%20output%20on%20display%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2145624%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E4%B9%8B%E5%89%8D%E5%B7%B2%E7%BB%8F%E5%88%86%E4%BA%AB%E8%BF%87%20imx8mp%20dts%20%E6%96%87%E4%BB%B6%EF%BC%8C%E9%A6%96%E5%85%88%EF%BC%8C%E6%82%A8%E9%9C%80%E8%A6%81%E5%9C%A8%20dts%20%E4%B8%AD%E6%AD%A3%E7%A1%AE%E8%AE%BE%E7%BD%AE%E8%AF%A5%E6%A1%A5%E6%8E%A5%E5%99%A8%EF%BC%8C%E7%84%B6%E5%90%8E%20adv7535%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B0%B1%E4%BC%9A%20%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2Flf-6.12.y%2Fdrivers%2Fgpu%2Fdrm%2Fbridge%2Fadv7511%2Fadv7511_drv.c%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2Flf-6.12.y%2Fdrivers%2Fgpu%2Fdrm%2Fbridge%2Fadv7511%2Fadv7511_drv.c%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2144961%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20ADV7535%3A%20No%20image%20output%20on%20display%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2144961%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F39586%22%20target%3D%22_blank%22%3E%40joanxie%3C%2FA%3E%EF%BC%8C%3CBR%20%2F%3E%3CBR%20%2F%3EFYR%EF%BC%8C%E6%88%91%E4%BB%AC%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E7%B1%BB%E4%BC%BC%E4%BA%8E%20Toradex%20%E7%9A%84%20%3CA%20href%3D%22https%3A%2F%2Fwww.toradex.com%2Fproducts%2Fcarrier-board%2Fyavia%3Fsrsltid%3DAfmBOoo7HCNe_HS9uHM4FI5Mt0_7K2JCvIVPtwJ1RXPhZWyMFykyBs9w%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EYavia%20%E8%BD%BD%E6%9D%BF%E7%9A%84%E5%AE%9A%E5%88%B6%E6%9D%BF%3C%2FA%3E%E3%80%82%E5%94%AF%E4%B8%80%E7%9A%84%E5%8F%98%E5%8C%96%E6%98%AF%E7%94%A8%20ADV7535%20%E5%8F%96%E4%BB%A3%E4%BA%86%20lontium%20DSI%20%E8%BD%AC%20HDMI%20%E9%80%82%E9%85%8D%E5%99%A8%E3%80%82%E6%88%91%E4%BB%AC%E9%80%89%E7%94%A8%20ADV7535%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%81%A9%E6%99%BA%E6%B5%A6%E4%B9%9F%E5%9C%A8%E5%85%B6%E9%83%A8%E5%88%86%E4%BA%A7%E5%93%81%E4%B8%AD%E4%BD%BF%E7%94%A8%E8%AF%A5%E5%99%A8%E4%BB%B6%E3%80%82%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E4%BB%AC%E5%9C%A8%20Toradex%20%E4%B8%BA%20%3CA%20href%3D%22https%3A%2F%2Fgit.toradex.com%2Fcgit%2Flinux-toradex.git%2Ftree%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx8mp-verdin-wifi-yavia.dts%3Fh%3Dtoradex_5.15-2.2.x-imx%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EYavia-WiFi%20dts%3C%2FA%3E%20%E6%8F%90%E4%BE%9B%E7%9A%84%E8%AE%BE%E5%A4%87%E6%A0%91%E5%8F%8A%E5%85%B6%E7%88%B6%E8%AE%BE%E5%A4%87%E6%A0%91%E6%BA%90%E7%9A%84%E5%9F%BA%E7%A1%80%E4%B8%8A%E8%BF%9B%E8%A1%8C%E4%BA%86%E8%AE%BE%E5%A4%87%E6%A0%91%E4%BF%AE%E6%94%B9%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E9%97%AE%E9%A2%98%E4%B8%AD%E7%9A%84%E8%AE%BE%E5%A4%87%E6%A0%91%E8%8A%82%E7%82%B9%E6%98%AF%20%3CBR%20%2F%3E%201%E3%80%82%3CA%20href%3D%22https%3A%2F%2Fgit.toradex.com%2Fcgit%2Flinux-toradex.git%2Ftree%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx8mp.dtsi%3Fh%3Dtoradex_5.15-2.2.x-imx%23%3A~%3Atext%3Dmipi_dsi%253A%2520mipi_dsi%254032e60000%2Cremote%252Dendpoint%2520%253D%2520%253C%2526lcdif_to_dsim%253E%253B%250A%2509%2509%2509%2509%2509%257D%253B%250A%2509%2509%2509%2509%257D%253B%250A%2509%2509%2509%257D%253B%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EMIPI-DSI%3C%2FA%3E-%E8%BF%99%E9%87%8C%E6%B2%A1%E6%9C%89%E4%BF%AE%E6%94%B9%E4%BB%BB%E4%BD%95%E5%86%85%E5%AE%B9%EF%BC%88%E4%B8%8E%E4%B9%8B%E5%89%8D%E7%9A%84%E6%96%87%E7%AB%A0%E4%B8%8D%E5%90%8C%EF%BC%8C%E6%94%B9%E5%9B%9E%E4%BA%86%E9%BB%98%E8%AE%A4%E5%80%BC%EF%BC%89%E3%80%82%E5%85%B6%E4%BB%96%E6%81%A9%E6%99%BA%E6%B5%A6%E8%AE%BE%E5%A4%87%E4%B9%9F%E5%BF%85%E9%A1%BB%E4%BD%BF%E7%94%A8%E5%AE%83%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E2%E3%80%82ADV7535%20%E7%89%B9%E5%AE%9A%E7%9A%84%E8%8A%82%E7%82%B9%E5%92%8C%E5%8F%A0%E5%8A%A0%E5%B1%82%EF%BC%8C%E6%88%91%E4%BB%AC%E5%9C%A8%E4%B8%8A%E4%B8%80%E7%AF%87%E6%96%87%E7%AB%A0%E4%B8%AD%E6%8F%90%E4%BE%9B%E4%BA%86%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%B8%BA%3CA%20href%3D%22https%3A%2F%2Fgit.toradex.com%2Fcgit%2Flinux-toradex.git%2Ftree%2Fdrivers%2Fgpu%2Fdrm%2Fimx%2Fsec_mipi_dsim-imx.c%3Fh%3Dtoradex_5.15-2.2.x-imx%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Esec_mipi_dsim-imx.c%3C%2FA%3E%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fgit.toradex.com%2Fcgit%2Flinux-toradex.git%2Ftree%2Fdrivers%2Fgpu%2Fdrm%2Fbridge%2Fsec-dsim.c%3Fh%3Dtoradex_5.15-2.2.x-imx%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Esec%3C%2FA%3E-dsim.c%2C%3CA%20href%3D%22https%3A%2F%2Fgit.toradex.com%2Fcgit%2Flinux-toradex.git%2Ftree%2Fdrivers%2Fgpu%2Fdrm%2Fbridge%2Fadv7511%2Fadv7511_drv.c%3Fh%3Dtoradex_5.15-2.2.x-imx%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Eadv7511_drv.c%3C%2FA%3E%2C%3CA%20href%3D%22https%3A%2F%2Fgit.toradex.com%2Fcgit%2Flinux-toradex.git%2Ftree%2Fdrivers%2Fgpu%2Fdrm%2Fbridge%2Fadv7511%2Fadv7533.c%3Fh%3Dtoradex_5.15-2.2.x-imx%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Eadv7533.c%3C%2FA%3E.%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%8E%B0%E5%9C%A8%EF%BC%8C%E5%9C%A8%E8%B0%83%E6%95%B4%E4%BA%86%E8%AE%BE%E5%A4%87%E6%A0%91%E5%8F%A0%E5%8A%A0%E5%B1%82%E4%B9%8B%E5%90%8E%E3%80%82%E6%88%91%E4%BB%AC%E4%B8%8D%E5%86%8D%E6%94%B6%E5%88%B0%20fin%E3%80%81fout%20%E9%94%99%E8%AF%AF%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E4%B8%8A%E8%BF%B0%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%20dev_dbg%20%E6%97%A5%E5%BF%97%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Etorizon%40verdin-imx8mp-15404184%3A~%24%20dmesg%20%7C%20grep%20drm%0A%5B%200.000000%5D%20Kernel%20command%20line%3A%20root%3DLABEL%3Dotaroot%20rootfstype%3Dext4%20quiet%20logo.nologo%20vt.global_cursor_defau%20lt%3D0%20plymouth.ignore-serial-consoles%20splash%20fbcon%3Dmap%3A3%20ostree%3D%2Fostree%2Fboot.1%2Ftorizon%2F7b778d635701b4e0bbc49652c%20421a587ae63ff3c6cbfc07d964084a23df7631d%2F0%0A%5B%202.771129%5D%20imx-drm%20display-subsystem%3A%20bound%20imx-lcdifv3-crtc.0%20(ops%20lcdifv3_crtc_ops)%0A%5B%202.771181%5D%20imx-drm%20display-subsystem%3A%20bound%20imx-lcdifv3-crtc.1%20(ops%20lcdifv3_crtc_ops)%0A%5B%202.772099%5D%20imx-drm%20display-subsystem%3A%20bound%2032e60000.mipi_dsi%20(ops%20imx_sec_dsim_ops%20%5Bsec_mipi_dsim_imx%5D)%0A%5B%202.772141%5D%20imx-drm%20display-subsystem%3A%20bound%2032fd8000.hdmi%20(ops%20dw_hdmi_imx_ops)%0A%5B%202.772468%5D%20%5Bdrm%5D%20Initialized%20imx-drm%201.0.0%2020120507%20for%20display-subsystem%20on%20minor%200%0A%5B%202.869610%5D%20imx-drm%20display-subsystem%3A%20%5Bdrm%5D%20fb0%3A%20imx-drmdrmfb%20frame%20buffer%20device%0A%5B%205.099098%5D%20systemd%5B1%5D%3A%20Starting%20Load%20Kernel%20Module%20drm...%0A%5B%205.188031%5D%20systemd%5B1%5D%3A%20modprobe%40drm.service%3A%20Deactivated%20successfully.%0A%5B%205.188992%5D%20systemd%5B1%5D%3A%20Finished%20Load%20Kernel%20Module%20drm.%0A%5B%205.262319%5D%20%5Bdrm%5D%20Initialized%20vivante%201.0.0%2020170808%20for%2040000000.mix_gpu_ml%20on%20minor%201%0Atorizon%40verdin-imx8mp-15404184%3A~%24%20dmesg%20%7C%20grep%20dsim%0A%5B%200.000000%5D%20Kernel%20command%20line%3A%20root%3DLABEL%3Dotaroot%20rootfstype%3Dext4%20quiet%20logo.nologo%20vt.global_cursor_defau%20lt%3D0%20plymouth.ignore-serial-consoles%20splash%20fbcon%3Dmap%3A3%20ostree%3D%2Fostree%2Fboot.1%2Ftorizon%2F7b778d635701b4e0bbc49652c%20421a587ae63ff3c6cbfc07d964084a23df7631d%2F0%20dy%0A%5B%202.759952%5D%20Kernel%20module%20loaded%20from%20ramdisk%3A%20sec_dsim%20-%20result%3A%200%0A%5B%202.771246%5D%20imx_sec_dsim_drv%2032e60000.mipi_dsi%3A%20sec-dsim%20bridge%20bind%20begin%0A%5B%202.771290%5D%20imx_sec_dsim_drv%2032e60000.mipi_dsi%3A%20version%20number%20is%200x1060200%0A%5B%202.772085%5D%20imx_sec_dsim_drv%2032e60000.mipi_dsi%3A%20sec-dsim%20bridge%20bind%20end%0A%5B%202.772099%5D%20imx-drm%20display-subsystem%3A%20bound%2032e60000.mipi_dsi%20(ops%20imx_sec_dsim_ops%20%5Bsec_mipi_dsim_imx%5D)%0A%5B%202.916294%5D%20Kernel%20module%20loaded%20from%20ramdisk%3A%20sec_mipi_dsim_imx%20-%20result%3A%200%0A%5B%203.259164%5D%20imx_sec_dsim_drv%2032e60000.mipi_dsi%3A%20p%3A%20min%20%3D%201%2C%20max%20%3D%206%2C%20m%3A%20min%20%3D%2088%2C%20max%20%3D%201023%2C%20s%3A%20min%20%3D%200%2C%20ma%20x%20%3D%205%0A%5B%203.259252%5D%20imx_sec_dsim_drv%2032e60000.mipi_dsi%3A%20fout%20%3D%20390000%2C%20fin%20%3D%2012000%2C%20m%20%3D%20130%2C%20p%20%3D%201%2C%20s%20%3D%202%2C%20best_delt%20a%20%3D%200%0A%5B%203.259262%5D%20imx_sec_dsim_drv%2032e60000.mipi_dsi%3A%20no%20pre-exist%20hpar%20can%20be%20used%0A%5B%2018.521539%5D%20imx_sec_dsim_drv%2032e60000.mipi_dsi%3A%20p%3A%20min%20%3D%201%2C%20max%20%3D%206%2C%20m%3A%20min%20%3D%2088%2C%20max%20%3D%201023%2C%20s%3A%20min%20%3D%200%2C%20ma%20x%20%3D%205%0A%5B%2018.521629%5D%20imx_sec_dsim_drv%2032e60000.mipi_dsi%3A%20fout%20%3D%20390000%2C%20fin%20%3D%2012000%2C%20m%20%3D%20130%2C%20p%20%3D%201%2C%20s%20%3D%202%2C%20best_delt%20a%20%3D%200%0A%5B%2018.521640%5D%20imx_sec_dsim_drv%2032e60000.mipi_dsi%3A%20no%20pre-exist%20hpar%20can%20be%20used%0Atorizon%40verdin-imx8mp-15404184%3A~%24%20dmesg%20%7C%20grep%20adv%0A%5B%200.000000%5D%20Kernel%20command%20line%3A%20root%3DLABEL%3Dotaroot%20rootfstype%3Dext4%20quiet%20logo.nologo%20vt.global_cursor_default%3D0%20plymouth.ignore-serial-consoles%20splash%20fbcon%3Dmap%3A3%20ostree%3D%2Fostree%2Fboot.1%2Ftorizon%2F7b778d635701b4e0bbc49652c421a587ae63ff3c6cbfc07d964084a23df7631d%2F0%0A%5B%201.052362%5D%20adv7511%201-0039%3A%20Rev.%2020%0A%5B%204.325789%5D%20systemd%5B1%5D%3A%20System%20time%20before%20build%20time%2C%20advancing%20clock.%0Atorizon%40verdin-imx8mp-15404184%3A~%24%20%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%9C%89%E4%BA%86%E5%AE%83%EF%BC%8C%E6%88%91%E4%BB%AC%E8%BF%98%E8%83%BD%E9%80%9A%E8%BF%87%E4%BD%BF%E7%94%A8%20i2cset%20%E7%9B%B4%E6%8E%A5%E5%9C%A8%20ADV7535%20%E4%B8%8A%E8%AE%BE%E7%BD%AE%E5%AF%84%E5%AD%98%E5%99%A8%E6%9D%A5%E7%94%9F%E6%88%90%E6%B5%8B%E8%AF%95%E8%89%B2%E6%9D%A1%E5%9B%BE%E6%A1%88%EF%BC%8C%E8%BF%99%E6%84%8F%E5%91%B3%E7%9D%80%20ADV7535%20%E8%87%B3%20HDMI%20Sink%20%E6%98%BE%E7%A4%BA%E5%99%A8%E7%9A%84%E5%B7%A5%E4%BD%9C%E6%AD%A3%E5%B8%B8%E3%80%82%E9%97%AE%E9%A2%98%E5%87%BA%E5%9C%A8%20iMX8MP%20%E4%B8%8E%20ADV7535%20%E7%9A%84%E9%80%9A%E4%BF%A1%E6%96%B9%E5%BC%8F%E4%B8%8A%E3%80%82%3CBR%20%2F%3E%E6%98%BE%E7%A4%BA%E5%B1%8F%E4%B8%8A%E4%BB%8D%E7%84%B6%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E8%BE%93%E5%87%BA%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E4%BB%AC%E5%B8%8C%E6%9C%9B%E4%BA%86%E8%A7%A3%EF%BC%8C%E6%81%A9%E6%99%BA%E6%B5%A6%E5%9C%A8%E5%85%B6%E4%BA%A7%E5%93%81%E4%B8%AD%E5%AE%9E%E7%8E%B0%20ADV7535%20%E7%9A%84%E6%96%B9%E5%BC%8F%E4%B8%8E%E6%88%91%E4%BB%AC%E5%9C%A8%E8%BD%AF%E4%BB%B6%E5%92%8C%E7%A1%AC%E4%BB%B6%E6%96%B9%E6%B3%95%E4%B8%8A%E5%AE%9E%E7%8E%B0%20ADV7535%20%E7%9A%84%E6%96%B9%E5%BC%8F%E6%98%AF%E5%90%A6%E5%AD%98%E5%9C%A8%E5%B7%AE%E5%BC%82%E3%80%82%20%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2138790%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20ADV7535%3A%20No%20image%20output%20on%20display%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2138790%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%9C%8B%E6%9D%A5%E8%BF%99%E4%B8%AA%E9%94%99%E8%AF%AF%E4%BF%A1%E6%81%AF%E6%98%AF%E4%BD%A0%E8%87%AA%E5%B7%B1%E7%9A%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E9%80%A0%E6%88%90%E7%9A%84%EF%BC%8C%E6%88%91%E5%9C%A8%20nxp%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%BA%90%E4%BB%A3%E7%A0%81%E4%B8%AD%E6%B2%A1%E6%9C%89%E6%89%BE%E5%88%B0%E8%BF%99%E4%B8%AA%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%80%8C%E4%B8%94%E8%BF%99%E4%B8%AA%E8%AE%BE%E7%BD%AE%E4%B9%9F%E4%B8%8D%E6%AD%A3%E7%A1%AE%EF%BC%8C%E4%BD%A0%E6%97%A0%E6%B3%95%E8%8E%B7%E5%BE%97%E4%BD%A0%E6%83%B3%E8%A6%81%E7%9A%84%E4%BB%BB%E4%BD%95%E6%97%B6%E9%92%9F%EF%BC%8C%E6%97%B6%E9%92%9F%E7%88%B6%E9%A2%91%E6%98%AF%2024Mhz%EF%BC%8C%E5%A6%82%E6%9E%9C%E4%BD%A0%E8%AE%BE%E7%BD%AE%E4%BA%86%2011Mhz%EF%BC%8C%E4%BD%A0%E5%8F%AA%E8%83%BD%E8%8E%B7%E5%BE%97%2024%2F2%3D12Mhz%20%E7%9A%84%E6%97%B6%E9%92%9F%E3%80%81%3C%2FP%3E%0A%3CPRE%20translate%3D%22no%22%3Eassigned-clock-parents%20%3D%20%26lt%3B%26amp%3Bclk%20IMX8MP_CLK_24M%26gt%3B%3B%0A%09%09%09%09assigned-clock-rates%20%3D%20%26lt%3B%3CSPAN%20class%3D%22%22%3E11000000%3C%2FSPAN%3E%26gt%3B%3B%3C%2FPRE%3E%0A%3CP%3E%E4%BD%A0%E5%8F%AF%E4%BB%A5%E5%8F%82%E8%80%83%E6%81%A9%E6%99%BA%E6%B5%A6%E6%BA%90%E4%BB%A3%E7%A0%81%E4%BD%9C%E4%B8%BA%E5%8F%82%E8%80%83%EF%BC%8C%E6%A3%80%E6%9F%A5%E4%BD%A0%E5%85%B3%E4%BA%8E%20lcdif%E3%80%81mipi%20dsi%20%E5%92%8C%20adv7535%20%E7%9A%84%E8%AE%BE%E7%BD%AE%E6%98%AF%E5%90%A6%E6%AD%A3%E7%A1%AE%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2Flf-6.12.y%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx8mp-evk.dts%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Elinux-imx%2Farch%2Farm64%2F%E5%90%AF%E5%8A%A8%2Fdts%2Ffreescale%2Fimx8mp-evk.dts%20%E4%BD%8D%E4%BA%8E%20lf-6.12.y%20%C2%B7%20nxp-imx%2Flinux-imx%20%C2%B7%20GitHub%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2Flf-6.12.y%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx8mp.dtsi%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Elinux-imx%2Farch%2Farm64%2F%E5%90%AF%E5%8A%A8%2Fdts%2Ffreescale%2Fimx8mp.dtsi%20%E4%BD%8D%E4%BA%8E%20lf-6.12.y%20%C2%B7%20nxp-imx%2Flinux-imx%20%C2%B7%20GitHub%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E5%8F%82%E8%80%83%E6%97%A5%E5%BF%97%EF%BC%8C%E4%BC%BC%E4%B9%8E%20pll%20%E8%AE%BE%E7%BD%AE%E4%B8%8D%E6%AD%A3%E7%A1%AE%EF%BC%8Cpll%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%9C%A8%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2Flf-6.12.y%2Fdrivers%2Fgpu%2Fdrm%2Fimx%2Fsec_mipi_pll_1432x.h%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Elinux-imx%2Fdrivers%2Fgpu%2Fdrm%2Fimx%2Fsec_mipi_pll_1432x.h%20at%20lf-6.12.y%20-%20nxp-imx%2Flinux-imx%20-%20GitHub%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BB%94%E7%BB%86%E6%A3%80%E6%9F%A5%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
