LWIP_DEBUGF
LWIP_DEBUGF
2,201 次查看
sandeep_c
thanks for the community
hi everyone may i know how to use debuggers  for troubleshooting code i want enable debug console for imixrt1170 processor how can enable that
like LWIP_DEBUGF
LWIP_DEBUGF(ETHARP_DEBUG | LWIP_DBG_TRACE, ("Can't move over header in packet"));
if i use above line where can i see the output it means tera term or anyother tool is required use or i need enable these things
thank you
@codebuger
2,170 次查看
jingpan
Hi @sandeep_c ,
You should define ETHARP_DEBUG and LWIP_DBG_TRACE first.
Jing
2,171 次查看
jingpan
Hi @sandeep_c ,
Jing
