LVDS display porting documents
2,729 次查看
hailiu
Dear community,
Are there documents or examples to describe  steps to porting LVDS display on imx6s/dl for a customer display with resolution 1024x768. I read through imx_reference_manual for linux-5.10.9 and it says the lvds driver is in driver/video/fbdev/mxc/imx_lvds.c and driver/gpu/drm/imx_ldb.c, but I can only find the second file. The other thing is that the node mxfb1 in device tree is disabled, Do I need to enable it?
thank you,
Hai
2,722 次查看
Hi Hai
one can look at Chapter 12 Connecting LVDS Panel   i.MX Porting Guide​
and example
https://community.nxp.com/t5/i-MX-Processors/How-to-change-SABRE-SD-screen-resolution-in-LOLLIPOP-5-...
2,705 次查看
hailiu
thank you,
I will go through the documents and see.
Hai
