LVDS Display Issue
LVDS Display Issue
5,121件の閲覧回数
leavs
I use IMX6DL, Kernel3.14.52, Uboot2015.04. Now I'm porting one LCD which is LVDS port. Follow is its timing.
My device tree config is follow:
I also check waveform from scope , clock is 39.9MHz
The attach is my LVDS LCD display.
Anyone can help me solve this problem ?
5 返答(返信)
4,887件の閲覧回数
rogerio_silva
Hi Leavs,
The waveform of your display seems to be equal from the one we use as default on i.MX6 SabreSD board. We use HSD100PXN1 from Hannstar.
About the timings, there are missing information on your table. As example, please check the document attached.
Rogerio
4,887件の閲覧回数
leavs
Thanks for your reply. I tested add <de-active> <pixelclk-active> <vsync-active > <hsync-active>  and change diffrent value, but the result is same to previous test.
4,887件の閲覧回数
please also check similar issues on
Cloning a display
LVDS output on Apalis i.MX6 (IXORA Board) - Toradex Community
4,887件の閲覧回数
Hi leavs
one can change fsl,data-width = <18>; and select appropriate kernel boot parameter
using Table 11. Common kernel boot parameters attached Release Notes,
try with nxp bsps described on
http://www.nxp.com/products/software-and-tools/software-development-tools/i.mx-software-and-tools/i....
4,887件の閲覧回数
leavs
Hi igorpadykov,
I had tested the data-width = <18>, but it didn't work. Do you have any other idea?
