LTIB (iMX6) : udevd[538]: init_udevd_socket: error getting socket: Address family not supported by protocol
1,876件の閲覧回数
Souvik
Hi, I am using iMX6 SABRE-Lite board. I am trying to build rootFS with option "minimum packages for rootFS" in Ltib. But when I am trying to boot the system with the built rootFS, I am getting following error. ................... .................. Freeing init memory: 148K hub 2-1:1.0: USB hub found hub 2-1:1.0: 3 ports detected starting pid 512, tty '': '/etc/rc.d/rcS' Mounting /proc and /sys Starting the hotplug events dispatcher udevd udevd[538]: init_udevd_socket: error getting socket: Address family not supported by protocol error initializing udevd socket udevd[538]: main: error initializing udevd socket Synthesizing initial hotplug events mount: mounting devpts on /dev/pts failed: No such device Setting the hostname to freescale Mounting filesystems mount: mounting devpts on /dev/pts failed: No such device mount: mounting usbfs on /proc/bus/usb failed: No such file or directory starting pid 626, tty '': '/etc/rc.d/rc_mxc.S' process '/etc/rc.d/rc_mxc.S' (pid 626) exited. Scheduling for restart. starting pid 632, tty '': '/etc/rc.d/rc_mxc.S' ......... ......... Can some one please help me to fix this error? Thanks and Regards, Souvik
タグ(2)
1,375件の閲覧回数
Matteo
have you solved the problem?
