LTIB build error: FslParserGetMetaData
1,635件の閲覧回数
Swamy
I am trying to build LTIB for IMX53 and I am facing following error when i try to build "gst-fsl-plugin".. please suggest...
aiurregistry.h:59: error: expected specifier-qualifier-list before 'FslParserGetMetaData'make[1]: *** [libmfw_gst_aiur_demux_la-aiur.lo] Error 1make[1]: *** Waiting for unfinished jobs....In file included from aiurdemux.h:52,                 from aiurregistry.c:42:aiurregistry.h:59: error: expected specifier-qualifier-list before 'FslParserGetMetaData'
Failed building gst-fsl-plugin
タグ(1)
1,550件の閲覧回数
Swamy
Thanks for the relply. Yes there was a wrong versions and now i matched both with common version and now i am able to compile.
Thanks once again for the support.
1,550件の閲覧回数
daiane_angolini
You should build fsl-mm-codecs too.
Have you donwloaded both packages (fsl-mm-codecs and gst-fsl-plugin) from fsl webpage? Are you using the same version of both?
