LTIB Installation Error
1,720件の閲覧回数
PrachiSinghal
I have started working on iMX51 EVK and started with following the steps to configure and install LTIB. I am following these two documentation for this:
 - http://www.freescale.com/files/dsp/doc/app_note/AN3875.pdf
 - http://secs.oakland.edu/~ganesan/iMX/i-mx-evk/installing-ltib/
 - ltib_build_host_setup.pdf from freescale website
 - imx51_evk_linux_bsp_userguide.pdf from freescale website
I am using Ubuntu 10.10 Virtual machine on VMware workstation. These are the series of steps that I followed:
1. Installing the dependencies packages
2. Downloading the LTIB source from Freescale's website
3. Editing sudoers file for permissions for LTIB
4. Changed directory permissions for LTIB directory (I was getting some permission related errors)
5. Executed ./ltib
I am getting the following error:
Processing deployment operations==================================
making filesystem image file
staging directory is /opt/freescale/ltib/rootfs.tmp
removing the boot directory and files
removing man files and directories
removing info files
removing /usr/share/locale directory
removing static libraries
find: pred.c:1932: launch: Assertion `starting_desc >= 0' failed.
Aborted
Died at ./ltib line 591, <> line 606.
traceback: main:591
Build Failed
Please help me regarding this error. I have tried to search about this online and even tried different patches for LTIB, but none seem to work so far.
I am counting on the expert's advice, please.
タグ(1)
1,480件の閲覧回数
G_rio
Is your host 32 or 64 bits? Have you tried to erase all in /opt/freescale , empty /tmp and reinstall the latest ltib ? Check the ltib requirements in doc's folder.
