LPDDR4 memory size requirement for Linux
aravindchakrava
We are building a custom hardware around iMX8M Mini and LPDD4. We will be running Yocto Linux in our board along with u-boot.
We wanted to know what is the minimum LPDDR4 size required for Yocto with all functionality.
Thanks & Regards,
Aravind
Hi Aravind
minimum requirements can be found for example on
https://stackoverflow.com/questions/27941775/what-is-the-minimum-amount-of-ram-required-to-run-linux...
For iMX8M Mini recommended to follow EVK design, as it was optimized for best performance.
Hi Aravind
