LEDx output signal for PCA9955
2,053 次查看
tomofumiyasuda
Hi All,
I control LED driver (PCA9955B) using i.MX RT1064. After I set each register and LED1 pin is output. However waveform from LED1 pin is negative voltage(-0.24V). The power supply of PCA9955B is 3.3V. What are the possible causes of this phenomenon? It is unknown whether software or hardware.
<PCA9955B data sheet>
https://www.nxp.com/docs/en/data-sheet/PCA9955B.pdf
TY
标记 (2)
1,931 次查看
tomofumiyasuda
Hi Jose,
Thank you for your reply.
The cause was hardware. I'm sorry to have caused you trouble.
TY
1,931 次查看
reyes
Can you please share your schematics for a review?
Jose
1,931 次查看
reyes
When you mentioned ‘waveform from LED1 pin is negative voltage(-0.24V)’, is this a negative spike or the voltage maintains at this level all the time?
I could use waveforms and schematics for a review.
Jose
