Hi all,
After downloading the newest BSP, I realized that it is completely Yocto-based. We are using PTXDist instead. I tried to extract the Vivante headers and binaries from the ext3 images and found only the libs.
Is there any download possibility to download these drivers and headers without using yocto?
thanks
解決済! 解決策の投稿を見る。
There is. In general, look at the related recipe and see SRC_URI value. Once you have it, you can wget/curl it.
But the easiest is to bitbake -c patch <package name> then work under the tmp/work/.../package-name folder.
Leo
Leo
The binaries can only be downloaded using Freescale’s BSPs so in the case of the latest it would require for you to use Yocto. This is the only way the binaries are being distributed as of today, as part of the BSP.
