Kitkat proxy issue in imx6 board
1,780 次查看
amit004
Hi, we are using imx6 board for our development and I am having some problem with the proxy setting. I see that if we open ethernet setting imx app and set the proxy it works.If we reboot the device it stops working. If we again launch the ethernet app and without doing anything just close, it will start working. If reboot again wont work. Did you guys see this issue or similar issue in kitkat.
标签 (2)
标记 (1)
1,604 次查看
haoranwang
Hi Kumar,
     Freescale Android kitkat Ethernet APK will removed the proxy when the apk "onDestory". You can see this in the source code.
Thanks.
1,604 次查看
amit004
I am sorry I am not able to understand you. I found that when we reboot we don't broadcast proxy settings in connectivity service even though proxy is set. By broadcasting the proxy while loading proxy setting solved the problem.
Amit
