J34 HDR
6,288 次查看
sapirbuz
I want to purchase the J34 connector PN 0922S0205011N9T-31RF (ANYTRONIC CORPORATION LIMITED) in the NXP evaluation board schematics A1, but I can't find it online.
Can you please offer an alternative connector compatible with the debugger or share the connector's properties? (dimensions, electrical char, etc.)
6,276 次查看
kerryzhou
Hi @sapirbuz ,
  J34, this one:
It is the very basic connector, from bom file, it is:
HDR 2X5 TH 50MIL CTR 172H AU 91L
https://www.mouser.com/c/connectors/headers-wire-housings/?pitch=1.27%20mm
Wish it helps you!
Kerry
5 回复数
5,274 次查看
paul_johnson00
@heardle 80s Thank you for your post. So great to find this topic.
6,277 次查看
kerryzhou
Hi @sapirbuz ,
  J34, this one:
Wish it helps you!
Kerry
6,271 次查看
sapirbuz
What is the meaning of:
CTR 172H AU 91L?
6,268 次查看
kerryzhou
Hi @sapirbuz ,
    I just copy it from the BOM file, in fact, you just need to care about this:
   HDR 2X5 TH 50MIL
  It is 2*5 header, and 50mil, it is enough for your selection.
Kerry
6,274 次查看
sapirbuz
thank you
