J1939 support
J1939 support
1,805 次查看
kishorekrish
Is J1939 protocol supports on your IMX6Q6AVT please explain me..
Thank you.
1,532 次查看
Rita_Wang
Hi kishore krish,
Yes,J1939 is a higher-layer protocol based on Controller Area Network (CAN). J1939 apparently uses the CAN 2.0b specification which is the same as what is supported in the FlexCAN module of the MX6Q (the 29-bit extended operation of CAN 2.0b).
Dan
Note: If this post answers your question, please click the Mark Correct  button. Thank you!
