Issues with poky make
ignisuti_
I'm new to poky, make compilations, and linux kernel building.
I'm trying to follow the instructions below for cross compiling, but running into errors.
First setup the cross compiler
$ source /opt/poky/1.5.2/environment-setup-armv5te-poky-linux-gnueabi
$ unset LDFLAGS
Now create the zImage
$ make -j4 zImage
When I run the last command, I get the following error: "make: *** No rule to make target `zImage'. Stop."
Can someone please help me understand what's going on?
Note: I'm running in a VM of Ubunut 14.04.
ignisuti_
I'm using the i.mx28 with Poky Dora.
joanxie
could you tell me what board and bsp version you use? what purpose of your poky using?
