Issues with Replacing SDRAM Chips on RT1052
1,929 次查看
zhangyuanhe
My RT1052 board uses the IS42S16160 32MB SDRAM, which works perfectly. However, after replacing it with the IS42S16400 8MB SDRAM, it fails to work properly. What configurations need to be changed?
4 回复数
1,903 次查看
Omar_Anguiano
You need to change the memsize of the device on the sdramconfig variable. This on the case that the only difference between the two is only the size, if there are more differences on timing  then the rest of parameters need to be tuned according the datasheet specifications.
Is the pinout of both similar?
Omar
1,863 次查看
OneByte
is RT1052 support 8bit of row_addr ? i can not SEMC_SDRAM_COL8()?
1,837 次查看
Omar_Anguiano
SDRAM device type with 2 banks or 8 columns is not supported.
Omar
1,190 次查看
OneByte
ok, thanks your answer about my question!
%3CLINGO-SUB%20id%3D%22lingo-sub-2076873%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9C%A8%20RT1052%20%E4%B8%8A%E6%9B%B4%E6%8D%A2%20SDRAM%20%E8%8A%AF%E7%89%87%E6%97%B6%E5%87%BA%E7%8E%B0%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2076873%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E6%88%91%E7%9A%84%20RT1052%20%E4%B8%BB%E6%9D%BF%E4%BD%BF%E7%94%A8%20IS42S16160%2032MB%20SDRAM%EF%BC%8C%E8%BF%90%E8%A1%8C%E8%89%AF%E5%A5%BD%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E5%B0%86%E5%85%B6%E6%9B%BF%E6%8D%A2%E4%B8%BA%20IS42S16400%208MB%20SDRAM%20%E5%90%8E%EF%BC%8C%E5%AE%83%E6%97%A0%E6%B3%95%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%E9%9C%80%E8%A6%81%E6%9B%B4%E6%94%B9%E5%93%AA%E4%BA%9B%E9%85%8D%E7%BD%AE%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2076873%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MXRT%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2185750%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Issues%20with%20Replacing%20SDRAM%20Chips%20on%20RT1052%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2185750%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%A5%BD%E7%9A%84%EF%BC%8C%E8%B0%A2%E8%B0%A2%E6%82%A8%E5%AF%B9%E6%88%91%E9%97%AE%E9%A2%98%E7%9A%84%E5%9B%9E%E7%AD%94%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2082018%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Issues%20with%20Replacing%20SDRAM%20Chips%20on%20RT1052%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2082018%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%B8%8D%E6%94%AF%E6%8C%81%202%20%E7%BB%84%E6%88%96%208%20%E5%88%97%E7%9A%84%E5%90%8C%E6%AD%A5%E5%8A%A8%E6%80%81%E9%9A%8F%E6%9C%BA%E5%AD%98%E5%8F%96%E5%AD%98%E5%82%A8%E5%99%A8%20(SDRAM)%20%E8%AE%BE%E5%A4%87%E7%B1%BB%E5%9E%8B%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E5%B4%87%E9%AB%98%E7%9A%84%E6%95%AC%E6%84%8F%EF%BC%8C%3CBR%20%2F%3EOmar%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2081677%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Issues%20with%20Replacing%20SDRAM%20Chips%20on%20RT1052%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2081677%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERT1052%20%E6%98%AF%E5%90%A6%E6%94%AF%E6%8C%81%208%20%E4%BD%8D%20row_addr%EF%BC%9F%E6%88%91%E4%B8%8D%E8%83%BD%20SEMC_SDRAM_COL8()%EF%BC%9F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2078671%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Issues%20with%20Replacing%20SDRAM%20Chips%20on%20RT1052%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2078671%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E9%9C%80%E8%A6%81%E5%9C%A8%20sdramconfig%20%E5%8F%98%E9%87%8F%E4%B8%8A%E6%9B%B4%E6%94%B9%E8%AE%BE%E5%A4%87%E7%9A%84%E5%86%85%E5%AD%98%E5%A4%A7%E5%B0%8F%E3%80%82%E5%A6%82%E6%9E%9C%E4%B8%A4%E8%80%85%E4%B9%8B%E9%97%B4%E5%8F%AA%E6%9C%89%E5%B0%BA%E5%AF%B8%E4%B8%8A%E7%9A%84%E5%B7%AE%E5%BC%82%EF%BC%8C%E5%88%99%E9%9C%80%E8%A6%81%E6%A0%B9%E6%8D%AE%E6%95%B0%E6%8D%AE%E6%89%8B%E5%86%8C%E7%9A%84%E8%A7%84%E6%A0%BC%E8%B0%83%E6%95%B4%E5%85%B6%E4%BB%96%E5%8F%82%E6%95%B0%E3%80%82%3CBR%20%2F%3E%E4%B8%A4%E8%80%85%E7%9A%84%E5%BC%95%E8%84%9A%E6%98%AF%E5%90%A6%E7%9B%B8%E4%BC%BC%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E5%B4%87%E9%AB%98%E7%9A%84%E6%95%AC%E6%84%8F%EF%BC%8C%3CBR%20%2F%3EOmar%3C%2FP%3E%3C%2FLINGO-BODY%3E
