Issues About DDR Configuration
1,642件の閲覧回数
tony_l_cai
Hi All,
     After filling the blanks About the Aid,I found not all params in the Aid are filled into the flash_header.s. And not all params in the flash_header.s can be found in the Aid script.So I want to know how to handle the relation between flash_header.s and Aid script.
     Another question, I use the ddr stress tool to  DDR frequency calibration, but after the number of loop cycle is up to 1479, the ddr haven't finish its test. And I want to know how many times this loop test need ?
     3q!
ラベル(2)
タグ(5)
1,470件の閲覧回数
Hi tony
please look at document below describing ddr test usage
i.Mx6DQSDL DDR3 Script Aid
after passing calibration ddr test runs in endless loop.
