Issue with floating point textures
1,395 次查看
michaeljope
I try to use an floating point texture using the latest driver 5.0.11.p8.41671 on the GC880 with OpenGL es 3.0 support. Shortly after uploading with
glTextureImage2D(GL_TEXTURE_2D, 0, GL_RGB32F_EXT, width, height,
0, GL_RGB, GL_FLOAT, dataPtr);
i get an Segmentation Fault. Maybe it went wrong as the texture data is accesed during the shader process.
What am I doing wrong here? If the texture is given as byte array everything wents well.
Thanks in advance.
标签 (3)
标记 (2)
1,287 次查看
Bio_TICFSL
Hi Michael,
Your code is right, But  you have to check the address where GL_texture_2D and dataptr are, this will create a segmentation fault, I can not see it.
Now texture data need to be clear no during shared process.
1,287 次查看
michaeljope
Hello Bio_TICFSL,
I dont't know what you mean with GL_TEXTURE_2D, its an constant in gl.h as far as I know. On the other hand, I ensured that data_ptr is valid. The segmentation fault is not when the function was called, but somewhat later.
I also ensured that there is no other thread/process involved by using this texture, if that's what you meant in your last sentence.
Michael
