Issue with basic_ios calls
1,242 次查看
ranjay_shandilya
Hi, I am MCUXpresso IDE for development of an application running on MXRT1050 with freertos. Everything works fine for me and I dont' get compilation error but when I run my application it get's hung at few calls which are in basic_ios.h. Eg: pStream->good() pStream->eof() present in basic_ios.h When I try to debug this I get a message the symbol doesn't exits. Is there any configuration or preprocessor I am missing or some include path. Board: MXRT1050 EVKB
1,232 次查看
PabloAvalos
Hi @ranjay_shandilya
Thanks a lot for using our community to let our technical support to assist you. I really appreciate that you were so patient.
Regarding your issue, I think that yes, it is necessary to add that library correctly, because that error is when the reference to some .h file is nof found, so it is just a warning on the compiler, so in order to help you, I would like to ask if you may share your code or project through our portal, so I can take a view to it to try to find the error.
I will send you an email, so you can post or reply on that. Please let me know if you have more questions.
Thank you in advance.
Best Regards.
Pablo Avalos.
