Hi @Abishek_1401,
I hope you are doing well.
Please mention the command that you are using for capturing the image
Please also mention documents that you have referred.
Kindly go through the Camera Sensor Porting Setup in V4L2 Mode in imx camera and display guide. We have found a similar problem case, for reference:
here
imx8mp ISP does support 12-bit RAW bayer output without any debayering. When applying debayered, only 8-bit YUYV is supported. If you want, we can provide the GStreamer command to get Raw:
here
One can try the other given solutions
here.
Thanks & Regards,
Sanket Parekh
