Issue facing while capturing IMX568 sony sensor in SRGGB12 raw mode
524 次查看
Abishek_1401
  1. I have integrated imx568 sensor in NXP imx8m mini  kit for 2 lane.
  2. I have added the pixel formats as SRGGB12 in both mxc_mipi_csi.c and mx6s_capture.c, but I'm unable to capture the frame using v4l2 control as raw image.
506 次查看
Sanket_Parekh
Hi @Abishek_1401,
I hope you are doing well.
Please mention the command that you are using for capturing the image
Please also mention documents that you have referred.
Kindly go through the Camera Sensor Porting Setup in V4L2 Mode in imx camera and display guide. We have found a similar problem case, for reference: here
imx8mp ISP does support 12-bit RAW bayer output without any debayering. When applying debayered, only 8-bit YUYV is supported. If you want, we can provide the GStreamer command to get Raw: here
One can try the other given solutions here
Thanks & Regards,
Sanket Parekh
