Is there any way to import data of object detection with gst-launch?
926 次查看
dpcivl
Hi, I'm really appreciated that I've been helped so much time in this forum.
Thank you for all of your help.
Anyway, I faced another problem.
I'm working with i.MX Machine Learning Guide.
With gst-launch, I'm doing object detection with my tflite model(mobilenet-ssd v2).
However, I can see the bounding boxes with my monitor but I want to import data like scores and classes that GStreamer has found.
If I want to use data from GStreamer, what should I do? Where can I find them?
My goal is to use them for variables of Python or C++ program.
902 次查看
Zhiming_Liu
You may need modify nnstreamer code or refer the nnstreamer documents
https://github.com/nnstreamer/nnstreamer/tree/main/Documentation
903 次查看
Zhiming_Liu
