Is there any documentation available for USB over-current detection in i.MX6ul?
995 次查看
hardikbehere
In our application, we are using over-current detection to control Vbus supply using Vbus enable pin.
But after detection of  USB over-current signal, processer assert a low signal to Vbus enable pin and remains low though USB device is removed from the device, we require to reboot the device to work USB again.
Hardik Behere
911 次查看
Hi Hardik
over-current one can check PP bit USB_nPORTSC1 description
in sect.54.6.31 Port Status & Control (USB_nPORTSC1) i.MX6UL Reference Manual
http://www.nxp.com/docs/en/reference-manual/IMX6ULRM.pdf
