Is the iMX RT1170 support DDR SDRAM interface?
已解决
跳至解决方案
2,416 次查看
shai_b
Senior Contributor II
Hi Team,
Can you please advise if our RT117x series supports the DDR SDRAM interface?
Thanks in advance
KR,
Shai
标签 (1)
1 解答
2,408 次查看
jeremyzhou
1) Can you please advise if our RT117x series supports the DDR SDRAM interface?
-- Actually, the RT117x series don't support connecting the DDR SDRAM.
TIC
在原帖中查看解决方案
2 回复数
2,409 次查看
jeremyzhou
TIC
2,402 次查看
shai_b
@jeremyzhou, Thank you.
KR,
Shai
